Please help with my power steering upgrade on my 68.
So I pulled the old Saginaw out and it went really smooth. I have a power steering gear from a 73 ready to go in. There are pictures below. The old, manual steering gear has a portion of the shaft exposed while the power steering gear does not. Is this normal? The overall length appears to be the same so does this look like the right unit? Am I good to proceed? If so I am going to buy a new rag joint just to be safe. I have the dimple in the frame and I will be buying 4 grade 8 bolts. I just want to let you all see before I go for it, thanks.
Member #1049
Re: Please help with my power steering upgrade on my 68.
Yes that is normal, just get the correct PS rag joint and bolt it on.
![]() Join Date: May 2008
Awesome, will do, thanks.
What are those "horns" looking things on the power steering gear for? There is on right between the t and the c.
Those are casting lugs to mount and locate the raw box casting for machining.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride! Where patience fails, force prevails Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle." |
Oh, I see, so they don't serve any purpose after manufacturing? I guess I was just worried about them somehow getting in the way during instalation since the box is so much bigger.
#8 | |
The Older Generation
Not a problem... lockDoc
cool, thanks
