Old 04-28-2011, 07:45 AM   #1
NoNeck
NoNeck's Avatar
Gas Tank Removal Tips
This will be my first gas tank removal. I have searched the forum for tips on removing the in-cab gas tank from my 1968 C10, and it seems pretty straight forward.
I have removed all the bolts and the gas gauge wire, and I have the tank loose right now.
My question is: Should I detach the fuel line coming up the face of the tank then bend the line away from the tank enough to get it out? I will be cleaning and reusing the tank, so I don't want to damage existing gas lines.
OR, is there another fitting in the line beneath the cab that should be disconnected?
Thanks!
NoNeck
2016 RAM Laramie HEMI
1966 Fairlane GT/A, 390/335 HP
If it costs you a dollar to make a friend, KEEP THE DOLLAR.
If it costs you a friend to make a dollar, KEEP THE FRIEND.
NoNeck is offline   Reply With Quote
Old 04-28-2011, 07:59 AM   #2
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
Re: Gas Tank Removal Tips
remove that line from the tank. there is enough flexiblity in that line to pull it away from the tank for an easy tank removal. if you have someone helping you its really simple but you can do it yourself. have had mine in and out a few times.
good luck
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 04-28-2011, 09:16 AM   #3
PatrickGMC70
PatrickGMC70's Avatar
Yeah, there should be enough flex. Also, it may seem obvious, but try to draw down as much of the fuel as possible. That sucker is HEAVY when it's full!
PatrickGMC70 is offline   Reply With Quote
Old 04-28-2011, 09:19 AM   #4
NoNeck
NoNeck's Avatar
That's what I thought, Harry.
I just didn't want to damage something trying to squeeze it out of there.
Thanks for the input!
Wayne (NoNeck)
Old 04-28-2011, 09:26 AM   #5
NoNeck
NoNeck's Avatar
PatrickGMC,
I had just poured 5 gallons of Non Ethanol 93 Octane ($4.12 per gallon) into the tank. All that fresh gasoline must have disturbed 3 years of sediment from the truck sitting in the weeds. Now I am getting trash in my clear fuel filter... I can't afford a new tank, so time to clean 'er up.
I have siphoned off most of the gas, so when my son comes up it should be a piece of cake.
Thanks!
NoNeck
Old 04-28-2011, 07:35 PM   #6
LockDoc
The Older Generation
LockDoc's Avatar
Wayne,
After you remove it, take the sending unit out and get as much of the gas out as you can. If you don't have a pressure washer take it to the car wash and use the hot water and soap and wash the crap out of the inside (so to speak) then rinse it good. After you do that blow it out good with a high pressure air hose. I put a couple of bottles of Heet in mine and sloshed it around to absorb what water was left in it, dumped that out, put it back together and it worked great.
LockDoc
Leon
Old 04-28-2011, 09:22 PM   #7
68gmsee
Active Member
68gmsee's Avatar
Sadly, after you go through all that trouble the rust will return in a few years.
I did that twice on my 68 GMC and finally had to replace the tank. Last year it developed microscopic pinholes on the bottom that were hard to see but sure could smell it.
If it's not too late here's some other tips:
Coat the rubber gasket with silicone or petroleum jelly to make it easier to slide the neck through.
Removing the seat is easier than to have to fight the tank through the back of it.
Tilt the tank up on the passenger side as you pull or if you have help, as they push on the neck.
If your seal is the original, order one from Classic Heart Beat. (scroll down) It's a GM product and won't deteriorate in a couple of years on you. Then all you need to do is cut the old one out (makes it easier to remove the tank), slide the new one in, silicone it or lube it and slip the neck back in.
68gmsee is offline   Reply With Quote
Old 03-11-2013, 06:38 PM   #8
Tillik
Tillik's Avatar
Where did you order your replacement tank from? LMC and Classic Industries seem solid. My local Orielly wants $274 + $60 shipping. I'm guessing its a Canadian company that makes them. I'm thinking of replacing everything to do with the gas tank to be safe. My current gas tank has so much crap/rust it in it's clogging my fuel filter etc. I just got the truck and want to get it running good for the summer.
James B.
1967 Chevy Fleetside Shortbed 4X2 (Black & Beautiful)
1971 Chevy Fleetside Shortbed 4X4 (White & Rough)
Tillik is offline   Reply With Quote
Old 03-11-2013, 08:03 PM   #9
68gmsee
Active Member
68gmsee's Avatar
Welcome to the site...
A few years ago I bought a Spectra made in Canada. Best fuel tank I've bought. Solid and fit perfect. Back then they had a sale for I believe $180 or so with free shipping. I don't think they sell them from their company to individuals anymore but you can get them through dealers (at an additional cost of course).
forgot: just enter the vehicle data on the left side for the truck you want to order for.
Here's one that has free shipping. http://www.autopartswarehouse.com/se...ctra+Fuel+Tank
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
Old 03-11-2013, 08:20 PM   #10
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Strange this one comes up just now.
This morning I had a starting problem. I've been suspecting the gas tank, but didn't REALLY want to deal with it.
This morning I checked the fuel line at the carb and, even with a healthy new filter, I found black flakes...small...but suspect,
and up at the carb connection ....Yetch.
Took off the carb, blew the lines out. Blew the carb out. Blew out the vent tubes.
Then, I thought I had better do it right. Pulled the tank. It didn't look bad in there. But, still. I started looking for a tank...
Big money for me right now. Called my guy at Napa in Coarsegold. With shipping, he was about $30 higher than O'Rielly on the Spectrum.
But he said, "If it's a decent tank, let my guy hot tank it...Two days...$115."
I'm in.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline   Reply With Quote
Old 03-11-2013, 08:24 PM   #11
TobyArnot
Quit if it's not FUN!!!
TobyArnot's Avatar
Thy these guys. They sell Spectra, which is as good as they get.
http://www.tanksinc.com/index.cfm/pa...rod/prd336.htm
TobyArnot is offline   Reply With Quote
Old 03-11-2013, 08:25 PM   #12
Tillik
Tillik's Avatar
After the fuel tank upgrade I'm installing an Intake, upgrading to Hei and I want to buy a new carb.
Thanks for all the input
James B.
Old 03-11-2013, 08:28 PM   #13
magwakeenercew2jh
Originally Posted by Tillik View Post
What model of Demon Carb is that? After the fuel tank upgrade I'm installing an Intake, upgrading to Hei and I want to buy a new carb. Demon has a good rep and will probably buy one.
PM'd you so's not to hijack the gas tank thread.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 03-11-2013, 08:34 PM   #14
68gmsee
Active Member
68gmsee's Avatar
That looks like a good price on the Spectra - even with the shipping.
06 Trailblazer
Old 03-11-2013, 08:40 PM   #15
Lattimer
Lattimer's Avatar
I just bought a new spectra tank from rock auto. That was the best price I found. Installed it over the weekend in about 2 hours. Hardest part was lifting the seat in and out.
Mine has a lot of rust inside and was fouling my filter. Also was smelling a lot of gas. No smell now.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 03-11-2013, 08:47 PM   #16
Nathans71
Nathans71's Avatar
My son and I removed our tank, put some phosphoric acid and water mix in. Then put a handful of roofing tacks in the tank and shook and shook. It took almost all of the garbage off the tank, inlcuding the rust. Drained, rinsed, let it dry and sealed with Eastwood tank sealer. No problems.
Nathans71 is offline   Reply With Quote
Old 12-14-2013, 08:45 PM   #17
Horne
Rockauto.com has a spectra tank plus shipping is under 200.00
1972 Chevrolet C-10 Stepside P/U (Build Project)
My Build Thread- http://67-72chevytrucks.com/vboard/s...43#post6421143
Horne is offline   Reply With Quote
Old 12-14-2013, 09:21 PM   #18
68gmsee
Active Member
68gmsee's Avatar
Good price for anyone looking for one. I bought one several years ago for $180shipped and it was the best one I've bought.
I just did a quick search and shipped to my area is $187.
06 Trailblazer
Old 12-14-2013, 11:51 PM   #19
cool68
have you checked with local radiator shops, like Chatt-Town Radiator Service, about repairing your tank?
cool68 is offline   Reply With Quote
Old 12-15-2013, 12:19 AM   #20
In The Ten Ring
I removed my tank last summer. Here is what I did. Like you, I took off the sending unit wire and all the bolts. I used a siphon pump to remove all the fuel I could (nearly 100% of it) and I used dishwash detergent (soap?) to lube the rubber grommet. It came right out!
My tank was coated with flash rust so I took it over to a radiator shop and they "renewed" it. It's more expensive than a new aftermarket tank but it's supposed to last forever. The shop had also sandblasted the exterior so I painted it with two coats primer and two coats of "hammered" silver. I painted the neck with 4 coats of gloss black.
I taped off the end of the filler neck (very end) and the place where the sending unit locks into so that I could be sure to get a smooth seal with the new grommet. I bought a new sending unit but I haven't put it back in yet.
Before removing the tank (didn't realize what trouble I had) I unhooked all rubber (and removed it) from the entire fuel line.
I now plan to make all new fuel line myself from Poly Armour, NAPA carries that. I bought my own flaring kit, bender, and tube cutter.
The renew process is about $250.00 BUT it guarantees you better results than an aftermarket tank, according to VWNate on here. I liked his arguments and I decided to go that route over the aftermarket tank route I had originally planned on. GOOD LUCK.
In The Ten Ring is offline   Reply With Quote
Old 12-15-2013, 10:00 PM   #21
Bob B.
Spectra makes the best tanks, no question. Have one in my truck. It is really not worth trying to repair a badly rusted tank in one of these trucks, particularly if it has holes in it.
The earlier post is right on about removal. Take the seat out, and lift the (empty!) tank from the right (passenger) side. It's pretty easy.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 12-15-2013, 10:23 PM   #22
TxTan
TxTan's Avatar
You should put a flame job on your fuel tank:-)
72 Chevrolet SWB Super
TxTan is offline   Reply With Quote
Old 12-15-2013, 11:22 PM   #23
twouvakind
twouvakind's Avatar
Spectra, yep. Check out Rock Auto...good price+fast delivery.
twouvakind is offline   Reply With Quote
Old 12-15-2013, 11:30 PM   #24
magwakeenercew2jh
You mean like this?
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 12-16-2013, 02:34 PM   #25
fisherman56
fisherman56's Avatar
Lmao!
fisherman56 is offline   Reply With Quote
