Old 03-26-2003, 02:52 PM   #1
ebber44
brake booster
i want to up grade my 71 c10 with power brakes, now can i use a new brake booster from a newer truck, can anybody help me?
ebber44 is offline   Reply With Quote
Old 03-26-2003, 04:41 PM   #2
lukecp
Formerly yellow72custom
lukecp's Avatar
Why not just get a booster for a '71?
I would go to a salvage yard, find a '71-'72 truck with power brakes, and take the booster, brakets, and vaccum line from the engine. I also think you have to switch master cylinders, but i'm not sure. I would call up the auto parts store and see if the part number for a '71 C10 with manual brakes is different than the part number for a '71 C10 with power brakes. Good luck!
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 03-26-2003, 07:30 PM   #3
72MARIO
72MARIO's Avatar
I heard that a booster from a 73-87 truck will fit you will have to make the push rod longer and drill some holes. I am going that route with my 67 I like the look better. Search under booster and 72MARIO you will find some info there
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
