04-28-2011, 07:56 AM | #1 |
Another Lowering spring question
On a 2in drop would I have to install lower shocks.... how low can I go befor I have to change them out.....
Posted via Mobile Device |
04-28-2011, 10:45 AM | #2 |
Happy to be here
Re: Another Lowering spring question
Are you talking front or rear? What year truck, and how are you getting the 2" drop. More details will help a lot in giving the correct answer.
04-28-2011, 08:51 PM | #3 |
87 silverado.... front springs only...... but seen some drop spindels for sell.. 97 suburban and the other one just says 88- 98 chevy.... I don't know what will interchange...
04-28-2011, 08:59 PM | #4 |
Happy to be here
You might be ok with the stock shocks for now. Anything lower and you will be better off with a replacement shock that specific to your drop.
The 97 suburban and 88- 98 chevy spindles will not work. You need 73-87 truck, 73-82 Blazer, or 73-91 Burb spindles. You will alos need to watch for standard duty with 1" rotors, and heavy duty with 1.25" rotors.
05-01-2011, 10:16 AM | #5 |
Thanks for the help...
05-01-2011, 10:53 AM | #6 | |
05-02-2011, 10:54 AM | #7 |
So what is the difference in the coil springs.. 87 and 94.....
Just going to cut them up..... are they tall. ,,,rafius Posted via Mobile Device |
05-02-2011, 06:32 PM | #8 |
If you cut the front coils one coil will it drop it one inch? I need to drop mine one inch.
05-02-2011, 06:42 PM | #9 | |
General rule of drop when cutting used coils for 63-87 trucks is 1-coil = approx 2" of drop.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 05-02-2011 at 06:43 PM. |
05-02-2011, 06:52 PM | #10 |
If I cut new original height coils, one coil, how much will it lower the truck
05-02-2011, 09:51 PM | #11 |
No more than 2".
05-02-2011, 10:21 PM | #12 |
Thanks, I will have to take the front end apart again and cut the coils. I am really getting tired of this.
