Old 04-28-2011, 12:06 PM   #1
sysock
wiring a trailer plug????
i want to wire up the seven prong plug to my 77 c-10 so i can pull my car trailer but am unsure how to do it. does anyone know how to do this? possibly a diagram of some sort, anything would be helpful.
thanks,
chris
sysock is offline   Reply With Quote
Old 04-28-2011, 01:41 PM   #2
Rons86
Rons86's Avatar
Re: wiring a trailer plug????
Get a trailer wire setup that plugs into the rear lighting harness. Would be a lot easier than splicing into the wires. From there it is pretty easy to wire up any type of plug. You can get them from Walmart sometimes or a trailer dealer would be sure to have them for under $20.
Rons86 is offline   Reply With Quote
Old 04-28-2011, 06:00 PM   #3
TDS-MN
Agreed, if you can find a 'plug-and-play' that uses the original harness, it's SOOO much easier. I got mine from Walmart years ago. You may need to look kind of deep to find the correct one for trucks this age, but you should be able to come up with one, and like said, should be under $20.
Otherwise, you can buy a 'generic' fit one that will have the 4 wires, and you will need to tap into your brake and turn signal wiring on your truck, which should be fairly easy as well, but will require you to protect that connection point from dirt/water to help avoid problems.
TomS.
'98 S-10 Blazer 4dr 4wd - 4.3, AT, stock
'85 K-10 w/ 305, 700r4, np208, and RUST!
SOLD Dec 2014
TDS-MN is offline   Reply With Quote
Old 04-28-2011, 09:12 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Just ask Mr. Google, he knows everything...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-28-2011, 09:58 PM   #5
hatzie
Moderator
hatzie's Avatar
There are a bunch of inexpensive plug-n-play T connectors for our trucks. No need to butcher the harness if it's un-molested. Just put some non conductive silicone grease in the plugs to keep the water out.
Hopkins 41105 Plug-In Trailer Vehicle to Trailer Wiring Connector
Old 04-30-2011, 01:08 AM   #6
Panelman55
Panelman55's Avatar
I have a Tee connector if you need one. Let me know.
Panelman55
In God We trust!!!
Panelman55 is offline   Reply With Quote
