Old 04-28-2011, 07:20 PM   #1
99-LS1-SS
99-LS1-SS's Avatar
Big block swap question
I plan on putting a big block in the Blazer after I get the body and frame closer to acceptable. My question is related to the transmission linkage. From what I've been able to determine the TH350 and the TH400 use the same linkage coming from the steering column. My question is, will that still be the case if I put a big block in the truck using 1972 big block motor mounts? Don't the factory style motor mounts for the big block move the motor forward some?
I know I'll have to get a custom driveshaft so that part doesn't worry me. The linkage is my next hurdle. I feel comfortable moving the transmission mount to where ever it needs to be and mounting it to the frame after I've got the engine in.
Am I missing anything obvious? If this topic has been discussed I wasn't able to find it in a search. If there are a bunch of links already just post them up.
Thanks!
99-LS1-SS is offline   Reply With Quote
Old 04-29-2011, 08:08 AM   #2
99-LS1-SS
99-LS1-SS's Avatar
Re: Big block swap question
Anyone?
Old 04-29-2011, 04:45 PM   #3
Burt4x4
Burt4x4's Avatar
First I don't know jack about Auto trannys.
I do know how too put a 454 errr BBC in a 72K5 cuz I did it.
BBC engine mounts were only in 2x4 applications ( no clue if using them in a 4x4 applications "moves" it forward or not?)
SBC engine mounts DO work fine with a BBC.
When I put in my 454 I used 73+ 4x4SBC engine mounts and crossmember. My engine is in the exact same place as my 350SBC was. I did not move my tranny/xfer mounts from factory.
SO - If you use SBC engine mounts it "shold" be in the same location as your current SBC is...
.025555 cents
Pass side looking forward, you can see the 73+ frame bracket with the 73+ SBC ORD engine mount...
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
