04-28-2011, 07:44 PM | #1 |
Vent window. very frustrated need advice.
so I went to pick n pull and mange to find a GMC and the vent windows weren't pitted and in really great shape. so after pulling them out I ordered new weather stripping for them. after reading on all the threads with tips on how to go about doing this. I know I don't have to stress how time consuming this whole process is. I ordered a vent window rivet kit off ebay from Grumpy's truck parts with 'flaring' tool for $18. Kit might have been worth $1.80 if that.
So I finally get the new weather stripping on and rivetted on the other channel. After trying to use this amazing rivet kit I noticed that it just split it more then 'flared' it, I finally get to the point where Its just about snug the arm/bracket that attaches to the vent window breaks. I already have about 3-4 hours into this PITA and now this happens. Is it possible to weld this back together or am I pretty much screwed? Any advice is appreciated. |
04-28-2011, 08:07 PM | #2 |
Re: Vent window. very frustrated need advice.
Cant help your break, but as far as riveting: I used a stainless 4-40 panhead with a locknut on both of mine. This way I can adjust the tightness.
72 Fleet (died) 78 Step (sold) 55 Step named Fred (sold) 00 F150 68 Step (named El Scorcho by PO) Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932 |
04-28-2011, 08:13 PM | #3 |
I know how you feel. We used to offer a rebuilding service for those but even with a high $$ hydraulic reviter and the parts cost and shipping, and time it takes it just was not a real money maker.
The revits are around $1.00 each( we sell them) and that tool is not worth much. If you use that tool you have to start the flare with a beveled punch to get it rolled over and then round it over using the tool you bought. We sell a better one but it costs too much for just one use. they just split or are lopsided if not careful. We won't even use that. You can do a better job with punches. You can weld the tab back on. Last ones we had re-chromed were around $35.00 to $40.00 each. Might be less work to find another used one here, then to fix that one. SOme guys use a pop revit on the inside rather than mess with the pivot revit. |
04-28-2011, 08:14 PM | #4 |
Moderator
I used pop rivets, no fuss, no problems. That tool is a joke. IIRC MBGMike has the correct tool that will press and flatten the traditional style rivets.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
05-03-2011, 11:32 AM | #5 | |
Does the vent window still swivel easily with using pop rivets or is it really tight? That'd make it a whole lot easier if that's the case! |
