Need some roof opinions......
Okay so my roof is pretty ruff, My question to all of you out there is should i try and buy a inner front panel and fix the outer skin or should I just cut it off and weld another decent one in place of it. I have somthing set up to get another roof for free. But lets get some feedback.
![]() Join Date: Nov 2003
Re: Need some roof opinions......
That is horrible. Definitely a new roof.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
HA..... I figured I would get that response.
The Older Generation
I had a cab like that and I scrapped it. It also had issues around both fresh air vents in the kick panels. (and other places)... LockDoc
Is the rest of the cab good
70 SWB STEPSIDE 70 BLAZER 09 challenger |
Everything on the cab is good except the roof. Rockers, and cab corners have already been replaced.
In TX you should be able to find a whole cab for relatively cheap and save yourself the time and expense of replacing that roof.
WOW! I thought the roof was bad in my 68! Joseph
1970 Chevelle Nomad station wagon 1966 C-10 lwb,250-six,granny 4speed ![]() ![]() 1966 C-10 lwb,factory A/C,Custom Cab ![]() 1954 Delray 2-door sedan [rat rod project]
lol.... yea it is pretty bad. But the really bad part is that sombody ( PO ) has some sort of copper filling all over the roof, i'm assuming it was where all the prior rust was...
#10 | |
The best plan would be to graph in halfway to the back of the door, half way down the pillar and a good 12 inches towards the center of the truck. There is at least 3 panels in that general area and odds are thay are all in pretty rough shape. Doing the inner and outer skins is a bit of a pain but it can be done with patience, finding and replacing the middle panel is a complete pain. Find a good cab or replace the whole top. The last 2 allow you the option of getting them cleaned and primed to do the swap in a weekend. Been there doing that.
we swapped roofs in my 69 LWB project, check my signature... wasn't too hard but if you have a better cab then i'd go that route.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
#13 |
Get the one for free if good and use it. WOuld not waste time and money on that. better cab is always the best route as stated. Or make a roadster
#14 |
Well I talked to one of our buddies on the board here and he is gonna meet me in Humble on sunday to drop off the roof, free of charge. Cant beat that so cutting off the roof and welding the used back on is the plan for now.
#15 |
Edit
Last edited by msgross; 05-01-2011 at 04:13 PM. Reason: please become a paid subscriber if you want to search for parts to buy, thanks... |
#16 |
Fabricate till you "puke"
Brace the cab, across the door openings, & an x cross the middle wouldnt hurt, before you cut the top off. Leave the doors on, & "fit" the new top to the truck. Take your time, & cut the pillars a tad long(grind to fit)....best of fun,crazyl
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
#17 |
yikes, weld on a new top section man, prolly your best bet.
#18 |
crazy longhorn said what I did to a tee , worked out really nice. Still would look for a good cab if I was in tx.
#19 |
Spanked once
![]() Join Date: Oct 2006
Here is some pictures in my build thread.
http://67-72chevytrucks.com/vboard/s...2&postcount=12 When I did this no one sold roof skins but the inside header was available. See how bad it really is by removing the header panel. You are not gonna buy another top that is not rusting already inside.
The ole 350 budget build. |
#20 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Good to see you deciding on a new roof as that's the route id go also.
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#21 |
Hay, maybe a convertable would be easier? Just kidding.
#22 |
![]() Join Date: Feb 2001
If rust isn't fully removed it will come back. You can pay now or pay later...my vote goes for a new roof.
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
#23 |
Well I have everything fitted up the best to my ability. Hoping to have everything on the roof welded up this weekend. I have been working pretty hard on getting all the front end stuff done, after the roof is finished it "should" be smooth sailing.... ( knock on wood )
