Old 04-29-2011, 01:47 AM   #1
rcbildr
rcbildr's Avatar
My 83 Z28
Just thought I would share a pic of my latest toy. It's a 305 with a 5spd T-top car. The PO installed the rear end from an 85 IROC so now it has posi and rear disk brakes, and he installed most of the interior from the IROC too. The clutch linkage is messed up and the tranny doesn't shift as good as I like it. It's driveable but I think I'm going to replace the tranny...I have a spare in my shop. The only other real issue is the t-tops leak but I can fix that with new seals eventually.
I'm trying to decide on what to do about the clutch linkage. It's the last year before hydraulic and my z bar is messed up...one of the arms was rewelded and I have to fix that...things just don't line up right. I want to buy a new z bar but I can't seem to find one at all...I checked ebay and craigslist. I thought about setting up an aftermarket hydraulic throwout bearing and adapting a mastercylinder to my stock pedals. Has anyone done this???
The PO also has the 700R4 with the drive shaft from the IROC that I'm going to buy...just not sure if I'm going to use it on the camaro or another project.
When I get ready to fix the linkage, I want to replace the clutch too. Is there one out there that doesn't require a lot of pedal force...a friend of mine was telling me about them but I can't remember what brands were suggested. All I remember is that they are kinda pricey.
Right now my goal is to get it reliable. Any thoughts/help will be greatly appreciated. Thanks!!!
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 05-02-2011, 01:10 AM   #2
lilpoindexter
lilpoindexter's Avatar
Re: My 83 Z28
I may have seen camaro Z-bar's in Classic Industries catalog for camaro...but it might have been for older cars.
lilpoindexter is offline   Reply With Quote
Old 05-02-2011, 07:02 PM   #3
rcbildr
rcbildr's Avatar
Re: My 83 Z28
All the restoration catalogs I've seen stop at the end of the second gen run in 81.
My Projects:
1978 Camaro Z28
Old 05-05-2011, 10:43 AM   #4
WIDESIDE72
WIDESIDE72's Avatar
Re: My 83 Z28
I have head good things about Centerforce clutches, but have never run one presonally. be prepared to PAY for it though.
WIDESIDE72 is offline   Reply With Quote
Old 05-06-2011, 06:39 PM   #5
rcbildr
rcbildr's Avatar
Re: My 83 Z28
I remember centerforce was one of the brands mentioned and I think that was at the bottom end of the price range. I know I'm going to have to shell out some cash, but if it will make the pedal feel a lot lighter I'm willing to pay for it. I just want to make it a good cruiser for now.
Hopefully in the next couple days or so I can get the z bar I have mocked up to be rewelded. I have the arm the clutch pedal rod goes to ground off and I made a new adjustment rod...the original was all bent up. I'm hoping I can get the bake booster/master cylinder out of the way enough to mark out where I need to weld on the arm on.
My Projects:
1978 Camaro Z28
