Old 04-29-2011, 06:28 PM   #1
John H.
John H.'s Avatar
What application is this for?
I was told this is from a 400 turbo 400 4x4?
I am going to list it in the parts section, but would like to get some type of description.
Thanks.
John H. is offline   Reply With Quote
Old 04-29-2011, 06:29 PM   #2
John H.
John H.'s Avatar
Re: What application is this for?
These might help!
Old 04-29-2011, 06:30 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
forgot a photo?
*EDIT*
Pics showed up as soon as I posted this.
Old 05-04-2011, 11:55 PM   #4
John H.
John H.'s Avatar
Ttt
Old 05-05-2011, 12:56 AM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Looks to be from a later model. The covers for these old trucks were stamped steel as far as I know.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 05-05-2011, 01:46 AM   #6
Livrat
Member #1049
Livrat's Avatar
Its for a mid 70's 4X4, they were used on both T400 and T350's (not sure which yours is for without a trans or another cover to compare) there is also a plate that bolts under the engine mount cups that the rods attach to.
Livrat is offline   Reply With Quote
Old 05-05-2011, 07:36 AM   #7
x2 ^
They were also used on 700r4s.
Old 05-06-2011, 06:41 AM   #8
Blazer1970
Blazer1970's Avatar
My '88 half ton 4X4 with a 700R4 had a setup that looked just like that. The rods go up to the motor mounts IIRC.
Blazer1970 is offline   Reply With Quote
Old 05-06-2011, 10:36 AM   #9
turp mcspray
turp mcspray's Avatar
I have an '88 burb with this same setup.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
