04-29-2011, 07:39 PM | #1 |
swaybar to replace track bar
can i use a sway bar to replace the track bar on the rear of my 64 chevy with trailing arms. im planning to bag this truck just trying to figure a way to keep axle centered with factory arms
04-30-2011, 12:08 AM | #2 | |
Re: swaybar to replace track bar
The Panhard bar (track bar) used in conjunction w/the truck arms keeps the axle centered relative to the frame but is limited in it's range vs. amount of side shift allowed. The longer the bar, the less side shift so using one as long as possible within your available space is the way to go. Another option is the Watt's link. It helps keep the axle centered exactly throughout travel but is definitely more complicated to set up. The sway bar in it's basic design won't do the job of the Panhard bar.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 04-30-2011 at 12:08 AM. |
04-30-2011, 12:58 AM | #3 |
Exactly, what SCOTI said, if your going to bag it get a watts link . It will keep your axle centered all the way up and down, the rear sway bar is only designed to reduce sway at one height. you will create some akward angles and side shift with only a sway bar, that the sway bar cannot correct with a bagged suspension.
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
04-30-2011, 01:14 AM | #4 |
VA72C10
sway bar would be a nice addition but you will still need a watts link or another option is an adjustable panhard bar if you're going to keep the driving height at a pretty standard preset. Can get it adjusted at ride height to center the axle. And those adjustable bars can be had CHEAP on ebay....
Looking for a 67-72 swb or blazer project in or around VA. |
04-30-2011, 08:10 AM | #5 |
thanks everyone i looked at the watts link but they are rediculous in price. i mean they sd wants almost 500 for their watts link. plus i dont really have the room to do a watts behind axle cause i want to run a blazer tank in the back
04-30-2011, 09:51 AM | #6 |
Happy to be here
You don't "need" a Watts link. Buy an adjustable track bar, center your axle at ride height, and call it done
04-30-2011, 12:40 PM | #7 |
but i want the axle to stay straight all the way up an down an the track bar wont let me do it
04-30-2011, 12:47 PM | #8 |
We can build you one
04-30-2011, 01:10 PM | #9 |
04-30-2011, 01:11 PM | #10 |
04-30-2011, 01:40 PM | #11 |
no prob. he is probbly talking a watts link. an how much would said watts link cast an how far behind the axle cover will it be at its furthest point
04-30-2011, 02:22 PM | #12 |
yes the watts link. Don't know on cost but should not be anywhere near $500.00 I will have to talk to Ronnie and see what he thinks. He can fab anything. Even Top fuel chassis's and rear ends. He is a CrewChief on a top fuel dragster, give us a dimension you have to live with
04-30-2011, 03:50 PM | #13 |
Happy to be here
So convert it to leaf springs, or a 3 link.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 04-30-2011 at 03:51 PM. |
04-30-2011, 05:56 PM | #14 |
was wondering it i put in a triangulated top bar on the rear with factory arms if that would take care of it
05-01-2011, 06:29 AM | #15 |
You know a bolt in watts link is 369 bucks http://www.kplinks.com/product.php?p...&cat=98&page=1 if you want cheaper talk to a local chassis shop they can build one that will fit even with the blazer tank in there.
05-01-2011, 10:59 AM | #16 |
on average how far behind the dif cover does the watts sit.
