Old 04-29-2011, 08:35 PM   #1
cst350
cst350's Avatar
Question Throttle Pedal measurement needed
Can anyone measure the distance from the top edge of their gas pedal to the floor/carpet? My truck is a 69, without the cable.
CST350
cst350 is offline   Reply With Quote
Old 04-29-2011, 09:52 PM   #2
gonzo6869
Cops, ha, catch me if you can!
gonzo6869's Avatar
Re: Throttle Pedal measurement needed
I don't have an answer for you, but maybe some more info from you to help someone answer it. Do you want this measurement to see how long of a cable you need? Are you trying to figure out the position of the pedal when you install your cable?
72 C-10 Stepper
350/TH350
3.73 in the back
Edelbrock intake and Carb
Hooker Comp Headers
275/60R15 on Rallies
gonzo6869 is offline   Reply With Quote
Old 04-30-2011, 12:21 AM   #3
cst350
cst350's Avatar
I have the other style, the solid rod. The difference from stock is that I'm running a Demon carb, so I dont know how long to adjust the rod so the pedal is in the stock position.
Old 04-30-2011, 12:39 AM   #4
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
If you use the factory adjustment method, I bet you can get close without measuring. Basically you just push the pedal till the lever hit the bump stop & hold it & with the carb at WOT adjust the thing on the rod till it goes in the hole on the throttle lever on the carb. Should put you in the ballpark.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
