Posi question...
I know that on an open diff, the wheels will turn opposite directions, you know, with the tires off the ground, and the way you tell if it's a posi is that the wheels will turn in the same direction. Is there any other condition that would have the wheels turn the same direction other than being posi?
I'm starting to think some PO may have changed the rear end out at some time. The rear brake lines are not stock, and both wheels turn the same direction. I guess I'll have to pull the cover to see for sure. Thanks
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
![]() Join Date: Feb 2001
Re: Posi question...
I am going to say no but I am mechanically challenged so lets get some experts to reply.
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
I would guess you have positive traction. If you're on a dirt road and you spin the tires do both tires leave marks?
Moderator
![]() Join Date: May 2007
sounds to me like you got posi...
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
This is the rule of thumb, but I have seen the opposite happen in both instances. You'll have to pull the cover to be 100% sure. It's probably due for some fresh lube anyway.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
#6 | |
![]() Thanks for the info, guys.
