Power Steering issues
Im trying to convert my 67 c10 from manual steering to power steering. I tried putting the power steering gear box on and it wont line up. Has anyone done this before?
The Gear box seems to be hitting the core support and will not sit flush with the frame!! Any ideas!?!?
1967 C10 Long Bed, Soon to have a 350 1997 Chevy 2500 454 BB |
72 Chevelle Club
Re: Power Steering issues
You will probably have to trim the core support bracket and your frame doesn't have the recess for the box so you will either have to cut it out or heat it with a torch and bend it in to match the gear box. The 67 didn't come with a power gear box they came with power assist steering which used the manual gear box and a slave cylinder on the front suspension and that's why you are having trouble .... Bob
I Have The Right To Remain Silent,But Lack The Ability 1972 Chevelle ... Mine 2006 Trailblazer... Hers 2002 Buick century ... Kids 2002 K1500 Z-71 EXT CAB ... Daily Driver 2005 Rockwood Roo ... For Camping 1974 Harley-Davidson XLH Sportster 84'' stroker |
Would cutting a notch out of the frame like that weaken its integrity?
72 Chevelle Club
yes you will need to fab and weld in a piece to conform to the contour of the box and keep the frame strong.
72 Chevelle Club
I will look tomorrow for better pics but here is one if you look close you can see the notch on a 67 frame that i cut . Keep in mind that this is before the patch was welded back in the frame .
#6 | |
![]() Join Date: Feb 2010
I did this upgrade to my '67, and used a PS box that came on my '70 (not sure if it was original or not). I had to notch the bumper bracket for the end of the box to clear, and just used some flat washers to shim the box away from the frame maybe 1/4". I know that this changes the center position of the pitman arm, and there may be other strangeness in the steering because of it, but honestly it is SO much nicer to drive now that I'll never notice that 1/4" of shift.
Do you know what year your PS box is made for? |
#8 | |
Active Member
![]() Join Date: Jul 2007
Sorry for the hijack but have a quick question for byates2.
I went to Auto Zone and they didn't have one in stock for me to look at. Do you know if your is 3.5 or 4.5 lock to lock? Also, what part number did you order? Mine came out of a late 70's or 1980 truck and is the 3.5 lock to lock. Has number 5686815 stamped on the end cap. |
#10 | |
looking at the reciept, it says the part number is #858670 but i'll let ya know what number is on the gearbox itself!
Active Member
10/4. thnx.
#13 |
Yea looking at the gearbox it has the same # yours does it also has another # on that reads 7802644
I think the gearboxes are the same for quite a few years! I did some research looking for powersteering to put on my 67 cuz they didnt come with it that year and it looked to me like they were all the same and i looked as far as 77 so i dont know. Thats why i orded the next year up cuz i figured it would be close enough to mount and it will with some slight modification.
#14 |
Scrapper 1
here is the one we all for get the factory box has more turns.The ones they sell you are Wrong. I've bought 3 of them dam things. and i always cum up short on my steering.If you can get a 4 1/2 turns get it cus the ones they sell are like 3 or 2 3/4 and we have a longer travel steering meaning to lock to lock we have to have more do to the new trucks have the steering box in the inside of the frame so more means when some moron take haft the drive way while your turning to a drive way you wont have to stop and back up to get another shot at it
