Old 04-29-2011, 10:56 PM   #1
AJLChase
AJLChase's Avatar
Brake line/fitting sizes?
How do you measure or know which size brake line fittings you need? I have a 67 CST 1/2 ton that I twisted the passenger side front line clean off with the nut attached and am not sure what size I need to buy to replace it? Any help?
AJLChase is offline   Reply With Quote
Old 04-30-2011, 08:02 AM   #2
JimKshortstep4x4
Re: Brake line/fitting sizes?
Stock brake line size is 1/4" for your truck. You might be able to buy a brake line that is close to the length you need so that reflaring is not needed.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 05-01-2011, 11:02 PM   #3
AJLChase
AJLChase's Avatar
Then would this be the right sized nut I would need to connect to my brake line hose?
http://shop.advanceautoparts.com/web..._A|GRP2037____
Old 05-01-2011, 11:19 PM   #4
mstrav1973
mstrav1973's Avatar
You can use a piece of string along the existing one to find out how long it is. Take the other end off and make sure the fittings are the same size on both ends and just head to NAPA or whatever parts house you use. They stock many sizes. You will also need a tubing bender to shape it to match the old one.
Matt
72 chevy k-10, swb, auto, 35's, rally's, posi, 4" lift, 2.5" old style 40 series flows with headers and crossover pipe and some other stuff!!
mstrav1973 is offline   Reply With Quote
Old 05-02-2011, 12:18 AM   #5
AJLChase
AJLChase's Avatar
Matt
Think I'll just take the whole line off from where it connects and just take it to NAPA or where ever and let them help me out...I think I've totally made the process harder than needed due to lack of experience...but by doing it this way I think I'll finally have it straightened out!
