04-30-2011, 02:17 AM | #1 |
2003 Suburban ISSUES
MOST not all of the time when I depress my brake pedal the right turn indicator on the dash, the front and rear bulbs as well as the right side signal mirror illuminate. When brake pedal is released they go off. Turn signals themselves seem to function properly. Also while holding the brake down I can sometimes get the right indicator to turn off with a few right turn signal lever taps... ANY help would be appreciated. Thanks for reading.
Chevy Trucks, Cold Beer, Grease, and The women that don't understand... Hey it's a way of life http://www.cardomain.com/ride/2993733 |
04-30-2011, 05:49 PM | #2 |
Re: 2003 Suburban ISSUES
Sound like a bad ground, Check the ground from the battery to the left fender & Ground# G401 Its mounted to the left rear body mount.
05-03-2011, 01:54 AM | #3 |
Thanks I will do that. Is that a common ground to go bad?
05-03-2011, 10:28 AM | #4 |
It is the ground to the brake computer and know to be an issue.
It is mounted under the cab right below where your left foot sits when driving.
Blaine 59 GMC 9314 a.k.a. Whoopee 68 C20 50th Anniversary a.k.a. The Rat http://www.flickr.com/photos/northerngmc/ http://www.members.tripod.com/P-wee/index_032.htm 1.61803 is one H of a lot better than 3.14159, no really it is! |
