Trailing arms touching chassis
Got the bed off my long fleet, i am going to do a small notch, got the measurements, with the air bag in the spring location fully aired out the trailing arm is the limiting point of how low i can go,
Question if i want to go lower what is the next step, I see porterbuild sell a crossmember for the front trailing arm location, but how much lower ? |
Redefining LowBudget
Re: Trailing arms touching chassis
the next drop is going to require you to spend some $$$$...relocate your bag mounts shocks,...its at the point to start thinking a 4 link
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
Senior Car Nut
![]() Join Date: Jan 2008
there was a recent thread about flipping the front trailing arm mounts rather than replace the crossmember but I don't see how that changes the eventual interference problem.
Larry |
#4 | |
Roofingbloke, what notch & bag set-up are you using? I've done more than 1 6x-72 w/the air bag in the stock coil location. With the bag deflated, I've yet to have interference issues w/the T/A hitting the frame. I'm curious about what might be different.
All rear end is stock at the moment, using slam 6" bags, 3.5" when aired out, 2" lowering blocks,
When i have done some measurements it works out that the upper edge of the axle will be 1" down from the top edge of the chassis, so no point in a step notch, so will be going for a small step notch, but i dont think i will get any lower without modifications to the crossmember that holds the front of the trailing arms, cannot afford new tubular arms so need to think some more, Thanks for the replys, Darron |
![]() Join Date: Jan 2011
The trailing arms will not hit the frame. The rear end will be the limiting factor and it will bottom out in the notch or the top of the housing will hit the bed floor first. With mine fully deflated I hit both about the same time.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
#7 | |
Dont want to go to the expence of a four bar. |
#8 | |
If the bag is in the factory placement between the frame & T/A, the T/A should not contact the frame (even w/the bag fully compressed @ 2.8" min height).
Here is a pic from when I was doing mine and it shows the bag with no air in it. I did not want to raise my bed floor so I don't have any blocks on mine. I need to put bump stops in the notches to stop the rear from hitting the wood in the bed. You have 2 inches between the arm and the frame as it sits in the picture.
Jimmy
My bags wont be in the origional coil spring location, therefore i will get more drop, hence the trailing arms hitting the frame will be a problem,
Anyone come across this problem also, |
#11 | ||
low n' slo
![]() Join Date: Mar 2009
did you offset the bag on the side of the frame and ta rather than bolting it in between?
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
#13 |
Just measuring at the moment,
I have a 63 long fleet. With 2" lowering blocks & bagi in spring location, when aired out the trailing arms are very close to the chassis (half inch) So if i want to go lower whats the next option, I dont want to go to the expence of tubular trailing arms, Anyone come across this situation. |
#14 |
low n' slo
you can move the bags on the side of the frame or put them over the axle, but the arm will still hit the frame. the only option from there is a link setup...then you have to move your bag.
or step the frame where the arm contacs the frame...then you can keep your original ta's. if you havent done your step notch yet you start the step from there...instead of just over the axle. check out puropedo's build..he did this same thing.
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] Last edited by kev2809; 05-02-2011 at 12:15 PM. |
#15 |
![]() Join Date: Feb 2010
my plan on fixing this when i do my rear setup is to move where the trailing arms connect. i am going to do this buy disconecting the crossmember for the arms strighten the arms out so they dont go out at such a angle and mount new brackets to the rearend and and re mount the cross member. for mounting the bags i am going to mount them on the outer rear frame and on top of the axle hope this makes sense
1966 C-10 long wide- currently with 2 3/4 sectioned crossmember, 3 inch cupped a arms with 2700 bags, 67 master cylinder, in the middle of a v8 swap, soon custom rear wishbone set up and bags 1942 chevy/divco ambulance 1937 chevy truck Last edited by Twiztid_66c10; 05-19-2011 at 06:40 PM. |
#16 | |
Long live SLIM ------------------ At least try to buy American ![]() |
#17 |
a guy i know has built and lowered these trucks for many years and has a big company in portland or. and he was the one who gave me this idea said he does this kinda thing all the time just gotta take your time and do it right
1966 C-10 long wide- currently with 2 3/4 sectioned crossmember, 3 inch cupped a arms with 2700 bags, 67 master cylinder, in the middle of a v8 swap, soon custom rear wishbone set up and bags 1942 chevy/divco ambulance 1937 chevy truck |
#18 | |
needs more $$$
I saw a rat rod type 65 at a show laying frame with stock t/a's and bags in the stock location. They z'd the rear frame right before where the t/a would contact the frame. I say "z" because it was done almost just like one where it was just cut, moved up and welded back together...not a typical step notch or custom back half. I don't know if this was safe, but he said he'd been driving for over a year and had no issues.
1970 2wd Blazer |
#19 |
low n' slo
if you plan to make new brackets to bolt the ta's too, why not build a 4 link? just curious, seems like it could save you the headache.
also, if you reposition the ta's where are you mounting your bags?
#20 |
cheaper moving ta's then 4 link already have all stuff there just need to make a couple brackets. i plan on mounting the bags on the outer side of the frame rail right above the axle. so one mount will be on axle and other on out side of frame on the c-notch
#21 |
low n' slo
ah, i see. i kept thinking you were mounting your bags on the sides of the ta's. be sure to post some pics..i would like to see how it turns out.
#22 |
Twizid, what did you end up with? I'm trying this same thing on a 73-87 frame
#23 |
my bags are in the post at the moment so wont know for a week or so,
also held up with my front end, i done a crossmember section, 1.25" and steering now hits crossmember so i am concentrating on the front whilst i am waiting for the post. |
