04-30-2011, 09:12 PM | #1 |
Which posi is this?
I decided to pop the cover off my diff today. I thought this truck had a posi, but I wanted to make sure:
Man, when I pulled the cover off, I thought someone had filled it up with tar! It was some mean looking goop in there. Should I try to rinse it out with something? I have heard it's best to use special posi oil-does anyone know what that is? Thanks
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
04-30-2011, 10:42 PM | #2 |
Has more rust than truck...
Re: Which posi is this?
Eaton clutch type posi. Its what came factory in these trucks. Spray/wipe it out with brake cleaner, fill with lube and the posi additive.
05-01-2011, 11:59 AM | #3 | |
Thanks for the Eaton info, BTW.
05-01-2011, 04:12 PM | #4 |
My Carbon Footprint
For what ever it's worth, if you ever wanted to be positive what your gear ratio is, it will be on the edge of the ring gear and the last numbers. Divide the little number into the big.
05-01-2011, 08:29 PM | #5 |
Yeah-I was going to do that very thing as soon as get it cleaned up a little. It was kind of a sideways step, pulling the cover off. I could have taken this truck for it's maiden trip around the block today if I hadn't. Now I need to get a gasket and some gear lube tomorrow when I get down to the big city. I think I'm gonna fill it with clean gear lube and put some miles on and then drain that and re-fill with the posi-lube and more new gear lube.
Thanks.
05-01-2011, 08:53 PM | #6 |
18 Till I Die
I would drive it for a couple months and change it again.
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... |
05-03-2011, 09:05 PM | #7 |
11:41=3.727272. I guess that must be 3.73's
05-03-2011, 11:09 PM | #8 |
Hmm, I didn't think Eaton's went that high. I thought 4.56 was as high as they went.
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress |
05-04-2011, 12:23 AM | #9 |
My Carbon Footprint
Exactly what mine was. Great gear with a 4 speed!
05-04-2011, 08:26 AM | #10 |
a better choice on lube is synthetic. the good stuff like royal purple does not need and posi additives either
05-04-2011, 12:44 PM | #11 | |
05-04-2011, 09:50 PM | #12 |
That's for round two. The old grease was so nasty I decided to fill it up with some plain old gear lube and run it for a few hundred miles then dump it again. I'll use a good sealer at that time. I just wanted it to be easier to clean up when that time comes. I did take it out for a little spin tonight, and it worked good, it locked right up when I broke the rears loose in some soft dirt.
05-04-2011, 10:02 PM | #13 |
#16876
^X2 but make sure you wear gloves!
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
