05-01-2011, 10:52 AM | #1 |
One more PS question - help please!
On the pic below with my power steering gear there are grooves then a gap and then more groves. Are the grooves closest to the steering gear for the rag joint and the outer grooves for sliding into the steering column shaft?
[/QUOTE] Last edited by ubtripn; 05-01-2011 at 12:41 PM. |
05-01-2011, 12:02 PM | #2 |
Re: One more PS question - help please!
No pic bro.
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 |
05-01-2011, 12:41 PM | #3 |
My mistake, here ya go. thx
05-01-2011, 01:19 PM | #4 |
PROJECT 7DEUCE
The whole rag joint assembly will slide on to the splines and then the steering column shaft will bolt to the rag joint assembly. Hope this helps ya..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
05-01-2011, 01:28 PM | #5 |
it does, thanks a ton! I thought for sure the shaft would go into the other. No wonder a good rag joint is so important for safety.
