Old 05-01-2011, 11:44 AM   #1
bignbad
bignbad's Avatar
tunnel rams
I saw this up at carlisle this weekend.Tunnel rams under a cowl hood.I thought you would need a higher cowl hood or a hole in the hood for tunnel rams.The motor looked like it was sittling lower in the truck but not sure.I didnt see the owner there at the truck to ask questions.Neat tuck though.
'72 chevy k20
'06 H-D Springer softail
http://www.bluemooncruisers.com/
http://www.enginecycle.com/
~Eric
bignbad is offline   Reply With Quote
Old 05-01-2011, 01:53 PM   #2
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
Re: tunnel rams
might have had a drop crossmember installed lowering the motor by a few inches .
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 05-01-2011, 02:09 PM   #3
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: tunnel rams
Motor could be lower but there is a lot of room under the hood of one of these trucks.May be he picked that particular tunnel ram because it was low enough to fit with just a cowl hood.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 05-01-2011, 02:17 PM   #4
Pop's C-10
Pop's C-10's Avatar
Re: tunnel rams
Looks like a stock motor mount set up...could be jus a good fit
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 05-01-2011, 03:09 PM   #5
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: tunnel rams
Pretty sharp truck do you happen to have any more pics of it?
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 05-01-2011, 04:05 PM   #6
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Re: tunnel rams
It's called Small Block Chevy. He also has the rear of the hood brace seriously notched. Just try doing that with a BBC! Look at how much more massive the BBC tunnel ram is.
prostreetC-10 is offline   Reply With Quote
