05-01-2011, 04:49 PM | #1 |
How do yo remove a glovebox without destroying it?
Anyone know a trick on how to remove a cardboard glove box on a 72 chevy c20 with AC without destroying it, mine is either new or just very well maintained and I simply need to find a wire that may have burned up behind it.
05-01-2011, 05:48 PM | #2 |
Re: How do yo remove a glovebox without destroying it?
Good luck. If they are a little worn you can usually finesse it out but if they are new or stiff good luck. The repops are fairly nice and inexpensive. Order a new one and do your best. If you ruin it you will have the replacement on the shelf.
I dammaged mine a bit removing it, some duct tape on the outside of it and you can't tell from the inside. I have a new one on the shelf.
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
05-01-2011, 08:10 PM | #3 |
its all about the +6 inches
i guess you could cut the dash...
Good luck. I don't think it can be done. |
05-01-2011, 10:36 PM | #4 |
I have removed mine a few times without damage, I just took out all the screws, collapsed it diagonally a little and the pulled it through the hole. I do get confused each time, eventually I get it set just right and it almost falls out! Just be patient. If you lose your patience just rip it out and stomp on it! A new one only cost $15 or so,
Posted via Mobile Device |
05-01-2011, 10:38 PM | #5 |
Rubbish. I've had mine out 2 or 3 times. Of course, it's new and not 40 years old. I like to start on the right side, carefully pulling the edge of the cardboard past the lip on the dash and working my way around. Once you get about half of it out, the other half slips right out. Just take your time with it. It might help to have a couple of beers on hand too...
-1967 Chevrolet Fleetside LWB- 350 V8 w/thumpr cam, NV3500, 3.08 gears, A/C, PS -1983 Chevy Silverado C1500- 383 stroker, TH400 -1989 Chevy Silverado K1500 SWB- 5.3L swap, 700R4, 3.42 gears -And a '66 Ford Mustang- 200 I6, C4 trans, rust bucket "The only thing we have to fear is fear itself." -FDR (and maybe rust too) You've gotta be able to stop and steer before you can go fast! |
05-01-2011, 10:38 PM | #6 |
Grandpa in the rustmobile...
^^^^^ funny
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
05-01-2011, 10:40 PM | #7 |
~Rest In Peace~
diamond plated it dude
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
05-02-2011, 07:54 AM | #8 |
To stick mine in I took the whole heater/A/C box out.
05-02-2011, 09:31 AM | #9 |
Active Member
Unless it was kept in a climate controlled garage and never used or the truck left in the sun it's probably going to crack or tear.
Cardboard simply doesn't last 40 years. I wouldn't worry about it though. If it tears simply order another. I've replace mine twice in the last 20 years. Texas heat is not kind to paper. |
05-02-2011, 09:34 AM | #10 |
it needs to be squished to remove by pulling out thru the glovebox hole// old petrified ones normally crumble when you try it tho
05-02-2011, 09:36 AM | #11 |
i got a catalog from the co that sent my frt marker lights...the new box is only 10 bucks. i'll see what co it is when i get home tonite.
05-02-2011, 09:39 AM | #12 |
I'm gonna make a bolt together one out of either steel or plastic..
I might even make a 2 piece fiberglass one.. I figure as good as place as any to learn how to make a fiber part.. I got my cardboard one out.. but it took forever.. |
05-02-2011, 10:40 AM | #13 |
Moderator
Yup
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
05-02-2011, 01:46 PM | #14 |
I have done it many times.
Remove all your hardware like screws and latches and so on and the glove door. Assure the heater/A/C hoses in back are not in the way. Next slowly start working the glove box at the top pushing back and pulling toward you; you have to have lots of patience for this part. A small straight slot screw driver may be helpful to slide along to work edges out. Once your satisfied with the top part being free then start on the bottom and if you can work the sides as well. The goal is to get it where you can get it sideways as much as possible then slowly remove it. If the cardboard is really brittle or badly falling apart, you may want to consider a 10 dollar replacement through a Vendor of your choice. Good Luck, if I was there I would help out. R/
Billy 1970 GMC Sierra Grande 402/TH400 (Longhorn)14 years and counting rebuild! 1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches 1970 Ford F250 Ranger 390 BB 2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires Hub Cap Freak! I need another truck like I need another hole in the head! I'M IN THE MARKET...AS IT WERE! |
05-04-2011, 09:56 PM | #15 |
My '72 had it's original in up until i decided to upgrade the stereo, antenna, wiper motor and washer pump. It had been removed once when we restored it 20 years ago and was extremely brittle when I tried to remove it a month ago. I ended up ordering a new one from LMC and after comparing them, I feel that it's a very nice replacement!
94 GMC Sierra GT with 66k original miles,'41 Chevy SOLD, '68 Chevy 1/2 2wd-2nd owner SOLD, '72 Chevy 3/4 4wd SOLD, '08 Chevy 1/2 4wd-service pickup, 2005 GMC 1/2 4wd 4 door lifted-my toy-SOLD, 2007 GMC Yukon XL Denali, 2009 Harley Street Glide |
05-05-2011, 06:35 AM | #16 |
72 Cheyenne Super 80 Silverado Blazer 2wd |
Tags |
glove box removal |
