Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 05-01-2011, 08:37 PM   #1
68c20lwb
68c20lwb's Avatar
bolt pattern help/question
hello, i am looking at getting a set of summer rims for my 98 S10 and i am wondering if these suckers will fit?
http://minneapolis.craigslist.org/hn...356363666.html
thanks guys!!
1968 C20 450hp 425ft-lbs 454/SM465 4.56's 2004 HD rims, needs paint and a 5th gear!
1969 C30 Open Road Motorhome 350/th400
1972 K10 350/350/205 Daily Driver -SOLD
68c20lwb is offline   Reply With Quote
Old 05-01-2011, 09:18 PM   #2
ka_jd7and1
is a fungineer
ka_jd7and1's Avatar
Re: bolt pattern help/question
Nope, S10s are 5 on 4 3/4". The big trucks (and some cars) were 5 on 5.
You need something off an S10, Camaro, or Monte Carlo, something like that.
2003 S10, 2.2 auto- the daily driver, currently with a 2"/2" drop and some minor engine bolt-ons
1978 Impala 2-door, race 350/T350 - the new race car, in progress
1968 Chevy C10 longbed- 3/5 drop, currently undergoing a heart transplant
ka_jd7and1 is offline   Reply With Quote
Old 05-27-2011, 06:42 PM   #3
cheford
You wouldn't know what cars had the 5 on 5 bolt pattern would you. I'm looking for a set of axles I need to narrow a rear diff. The axles that I have from the pickup diff is under cut by the splines and can't be machined.
I was told the an 92 to 97 S10 zr2 had a 30 spline axle that is supposidly 1 1/4" shorter than the C/K series trucks, if this is so could they be drilled out to a 5 on 5 bolt pattern?
cheford is offline   Reply With Quote
Old 05-28-2011, 09:40 PM   #4
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Old Lincolns and Caddillacs had 5X5 and disc brake options. 94-96 SS cars also have 5X5 bolt patterns.
The ZR2 axel is wider than a standard S10. I'm not sure on the exact dimensions.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 05-29-2011, 07:41 PM   #5
cheford
I just found out that the 1991 to 1996 Chev Caprice has a 10 bolt differenial that is 60.7 inch wide and has a 5 on 5" bolt pattern. Now I have to find one.
