![]() Join Date: Nov 2010
What is my truck?
Can someone help me figure out what my truck is considered? I thought that it was a long horn but there are no holes for the emblem on the box sides. it does have the extra long bed. Also has anyone ever seen a paint scheme of med olive, yellow, med olive? ![]() Thanks in advance, C
Re: What is my truck?
looks like a longhorn to me could have had the fenders replaced or filled then painted just a guess though.
I've been stripping it to bare and did not find the holes. I did find factory paint under the grey on everything. The truck was olive and yellow with a yellow and black interior.
thats lookin good bro , going all the way down to the metal is what i did also little more work but well worth it
![]() Join Date: Jul 2010
That some good looking metal under that cab..
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
I got lucky just a little rust on it. surface rust on the frame was the worst of it. I was going to paint the frame till I found out about POR15. WOW THIS STUFF IS AWSOME!!
Thanks! Removing all the old under coating was a real - well you know!
VA72C10
![]() Join Date: Mar 2008
Nice job! Truck is looking good and the wheel base and bed tell me it's a longhorn...
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
its all about the +6 inches
it's a longhorn, no question about it,
There were 3 part numbers for the longhorn bades, I'm not 100% sure which one was used and when, nor what the differences were, but I know that many of them were glued on, and not bolted. |
The Niner
Great looking truck!
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
![]() Join Date: May 2007
Wow!! I thought all of these trucks came from the factory with rusty floor supports! LOL!
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
Looks great! What did you use to clean the underside and get it down to metal?
Brad 72 Blazer CST 350/350/205 ![]() ![]() |
#13 | |
![]() To clean the underside I presoaked it in BEAN-e-doo (soybean based no gloves or mask needed 100% biodegradable), then I let it dry and hit it with the tools pictured. If you look close you will see a few oddballs - I used a pipe cleaner (used when roughing up the joints on copper pipes) to hit the real tight spots, I also glued a foam pad on to my electric sander so I could use sticky sand paper instead of having to buy the more expensive "hook and Loop" stuff. Missing from pictures are TIME, ELBOW GREASE, and some GOOD TUNES. ![]() Did this post get moved? Should I post this in another area?
#14 |
Yep, I agree, it's a Longhorn
1972 C-10 Custom Deluxe 468 BBC w/ TCI 400 Trans |
#15 |
How about the colors and options(or lack of)? has anyone run across the color combo before? med olive&yellow&med olive with a yellow and black interior and yellow firewall? Also what do the other options mean? Like no slip? is that posi or one wheel peel? This is my first build and unfortunately I have a whole buncha questions. Is there a site you can go to to see what it all means?
#16 |
According to the color chart, code 573 is primary paint code 525 yellow and secondary or two tone color code 504 medium olive.
So the firewall would have been the yellow as was the entire truck with a medium olive roof and centerband if that was the two toning scheme. Yes that is a detroit locker diff! Posi! Cool truck! Tim |
#17 |
Cheyenne?
#18 |
Its a 70 so option code Z84 = CST, same as Cheyenne option in 71 & 72
#19 |
does longhorns not have their own vin number to i.d them? odd seeing gas door in seam. mine is not, nor have i seen one this way.
In the words of my favorite poet, singer/songwriter (Paul Thorn) ![]() |
#20 |
longhorns have there own model number, but not VIN, there is nothing in any 67 - 72 chevy truck to tell what the wheelbase is.
For the 3/4 ton, a six cylinder will be a CS21034, while the V-8 trucks should be CE21034. If you're dealing with a one ton truck, the six cylinder will be CS31034, and CE31034 for the V-8 trucks. This info and more can be found on my longhorn web site, http://www.longhorntrucks.freeservers.com/ |
#21 |
model number, thats right. thanks for the correction.
#22 |
Longhorn Man, do you know if the side gas tanks were reproduced? Where can I find new ones?
#23 |
It's a Chevy
![]() ![]() Posted via Mobile Device
1969 Chevy c20(Miss Hackjob) |
#24 |
![]() Join Date: Sep 2010
With the 133 inch wheelbase . . . it's a Longhorn !! Below, is a picture of someone else's "John Deere" 70 C-20. . . . . |
#25 |
![]() Join Date: Nov 2001
It just hit me !! Now I know what the problem is with them eight foot bed owner's !!! There kind of like the middel child. Not a Longhorn not a Short Bed but the middle bed. lol .Sorry it just came to my head, maybe I sould go back to bed not enuff sleep and that probly cuase my bed's short. lol. Go ahead Longhorn's laugh but we got nothing to hide. lol. O.K-O.K I'm moving on. Nice work on nice truck you got there. Nick
