05-02-2011, 01:29 AM | #1 |
lug patterns
So i was initially going to keep the 6 lug pattern on my 68 C10, but due to wheel options and other details involving the brakes I want i'm going to be changing out to 5 lugs. My question is are the Chevy 5 lug patterns the same as a Ford? I am thinking of putting a Ford 9 Inch rearend in place of the 12 bolt.
05-02-2011, 02:49 AM | #2 |
VA72C10
Re: lug patterns
some chevy and ford wheels are the same. The stock chevy pattern for 5 lug is 5 x 5. If you can verify the ford, you should be good. Moving to suspension for you....to get some more qualified guys to confirm
Looking for a 67-72 swb or blazer project in or around VA. |
05-02-2011, 02:55 AM | #3 |
Re: lug patterns
depends om what tha 9 in came out of..here is a list 0f what was 5x5
FORD FULL SIZE (CUSTOM, GALAXIE, T-BIRD) 73-78 FORD Custom 73-78 FORD Galaxie 73-78 FORD LTD 73-78 FORD Thunderbird 72-76 You can have tha axle redrilled & get aftermarket one's
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
05-02-2011, 09:51 AM | #4 |
Re: lug patterns
These days, the most common F**d 9" found is out of trucks. They're a 5x5.5" pattern.
