Best way to fix this?
Re: Best way to fix this?
Yep looks pretty normal. go search the paint and body section lots of good posts
I am working on the same thing, lovely rust. i am using a complete floor edge piece that goes from firewall floor seam to the back wall/ cab corner. it has about 4" of floor and complete inner rocker. it also has the floor support to pillar bolt holes in it (for ease of alignment. i bought mine locally but same taiwan parts.
item #7 in the LMC diagram http://www.lmctruck.com/icatalog/cb/full.aspx?Page=25 im sure other people have pics of the whole process and some advice, anyone ?
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
I guess my next stupid question is then...Am I supposed to remove those rusty bolts on each side. The ones holding the cab suport to the inner rocker? Also, If I remove the rest of this inner panel and the bottom of that rusty a pillar. Will I need a cab brace or will it not flex. Thanks guys new to the body side of things and this is harder than I thought
#5 | |
#7 | |
#8 | |
Yes remove the rusty bolts holding whats left of the floor to the cab floor support. From what i have read from other threads you do not have to brace it unless the (outrigger?) front to rear floor support ( what the side to side supports are attached to) are rotted. or if you are removing the roof for chop or replacement.
I removed the rocker and the inner came off with it, it was rusted off behind where the door weatherseal was. then i measured where the floor edge repair panel would reach to and cut it rough within about 1/2" of where the floor edge repair piece should line up to. then i placed the new A pillar over the existing rotted pillar and marked it and cut it out just below the 2 upper bolt holes of the lower hinge mount and shaved a little off the replacement pillar to line it up. be carefull not to cut through the lower hinge mount cage nut thingy and if you can try to preserve the lower part of the cage that is spotwelded to the A pillar just under the lower bolt hole of the hinge. you will need to reattach that to the new A pillar. then i cut out part of the existing kick panel and placed the repair kick panel over it to mark and cut out the remaining existing kick panel then again test fit the A pillar with the kick panel in place and then test fit the rocker with those pieces held in place with sheet metal screws. now i am at the point where i just drilled out the spotwelds holding the cab corner to the rear pillar bottom (B pillar??) and i need to order the lower B? pillar to finish test fitting, cut an exact line for the floor edge repair panel and weld it all into place. heres a few pics of what ive done so far hope these help you out .
It definately gets a little scary after you first look at it and think "its not that bad" then every piece behind the one you remove is worse than the one before it. just take your time and don't get overwhelmed its only metal.
#11 | |
Active Member
![]() Join Date: Jul 2007
![]() Good way to think about it. Got to just go for it. |
any progress ?
#13 |
Not much, Little by little. Im having a bear of a time getting all this done..Ive got the panels bought and marked where to cut, and ive got almost all the drivers side rusty areas out and cleaned up. Going to put aside some time to get out there and go for it. Im terrible at this..Oh ya ill post pictures a little bit later. Thanks
#14 |
saving
1969 Chevy c20(Miss Hackjob) |
#15 |
Take lots of measurements. I mean lots!
New parts don't just slip back in. It will need some massaging. Some more pics here (starts bottom of the page) - http://67-72chevytrucks.com/vboard/s...=217490&page=4 I used that same 'item #7' as well.
1972 K2500 Long Box 400/350 |
#16 | |
#17 | |
#18 |
any updates for us seeker ?
Thanks freakshow im just working a little at a time trying to do it right with alot of thinking and measuring before welding . I have my rear pillar from LMC since the local shop doesnt have that one piece. cut out the cab corner, bought a big sand/media blaster since my chinese siphon gun crapped out , some black diamond media, a mig conversion kit for my hobart handler 125 and a 3M respirator. It is definately a good idea to buy rust free for all you newbies since i could buy another truck with the $ i have in rust repair and im only about halfway in financially for the rust repair. I snipped the difference out of the outer floor edge today now i just need to cut the remaining bad section out of the floor and trim my floor pan to fit , then media blast it and triple check the fitament of everything before putting it all together and welding it in. I really should start my own build thread soon but the work and family leaves little time for the truck and the wife loves to occupy the macbook... later
#19 |
Yea, I havent been working on the truck as much as Id [I]Like[I] to have been but I am getting there
