Old 05-03-2011, 02:00 AM   #1
bartsim
1957 4x4
bartsim is offline   Reply With Quote
Old 05-03-2011, 10:32 AM   #2
68panelman
68panelman's Avatar
Re: 1957 4x4
That is sick!!! Awesome truck. Give us some details, specs!!
68panelman is offline   Reply With Quote
Old 05-03-2011, 06:38 PM   #3
LeftCoast32
Custom Builder
LeftCoast32's Avatar
Re: 1957 4x4
Killer Truck!!!
LeftCoast32 is offline   Reply With Quote
Old 05-03-2011, 09:03 PM   #4
d-666
d-666's Avatar
Re: 1957 4x4
wow!! just wow!
1990 k5 blazer
1990 gmc jimmy
1949 1300 p/u-sold
1977 bbc skylark
96 roadmaster
06 9c1 impala
d-666 is offline   Reply With Quote
Old 05-03-2011, 09:26 PM   #5
71Sixer
71Sixer's Avatar
Re: 1957 4x4
Now that is COOL!
71Sixer is offline   Reply With Quote
Old 05-04-2011, 12:03 AM   #6
Redcap
Re: 1957 4x4
Wow. That thing is a beauty.
Redcap is offline   Reply With Quote
Old 05-04-2011, 06:50 AM   #7
propanemudtruck
Local Redneck Authority
propanemudtruck's Avatar
Re: 1957 4x4
no flippin way! That's a sweet truck!
-Kevin
four on the floor feel the beat in your soul
movin to the rhythym pumpin til ya cant take no more
dance if you want to do what you came to
you cant ignore the feeling of that four on the floor
propanemudtruck is offline   Reply With Quote
Old 05-05-2011, 01:36 AM   #8
bartsim
Re: 1957 4x4
Thanks for the comments.
Old 05-05-2011, 01:40 AM   #9
bartsim
Re: 1957 4x4
Thank you. It has a ZZ4 create motor, th-400, Dana 60 up front and a corporate 14 in rear. Crossover steering. I drives great...a little rough but thats half the fun.
Old 05-05-2011, 01:42 AM   #10
bartsim
Re: 1957 4x4
Anyone use a disc brake conversion for a Corporate 14. Just looking for any pitfalls.
Old 05-05-2011, 11:43 PM   #11
lukefalls
Re: 1957 4x4
Put a conversion kit on my 71. Absolutely no problems or pitfalls. Same Truck, same axle: now and before.
lukefalls is offline   Reply With Quote
Old 05-07-2011, 07:46 AM   #12
silver7
silver7's Avatar
Re: 1957 4x4
Un friggin believeable. Love the black rims against the green with the older truck. Your attention to detail is unbelieveable. Well done!
I am trying to do something similar with my 71 4x4 using 20" KMC Diesel rims. Assuming you used stock axles, how did you get your wheel studs to handle the aftermarket rims? When I went to mount my rims on the OEM wheel studs I found the studs to be about an inch too short due to the extreme hub thickness of my Diesel rims.
Shawn
1971 C10 4x4
silver7 is offline   Reply With Quote
Old 05-07-2011, 10:11 AM   #13
TheWhiteElephant
God is good!
TheWhiteElephant's Avatar
Re: 1957 4x4
I have wanted to do the same to mine, but I would have to use the Eldorado calipers which have been a little hard for me to find, and when I do find them they are too expensive.
I don't want to lose my emergency brake and as far as I know, that's the only way to keep it. I have seen some other new calipers with the built-in ebrake on Speedway, but I'm not sure if they will work.
If you don't "need" the e-brake or need it to pass inspection, then the conversion is the way to go. There are a whole lot of how-to's all over the 'net that show you how to do the conversion.
Killer truck, by the way.
Mando
"It takes a smart man to know when he's stupid." -- Barney Rubble
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367
TheWhiteElephant is offline   Reply With Quote
Old 05-07-2011, 07:58 PM   #14
lukefalls
Re: 1957 4x4
High Angle Driveline makes an E-Brake kit that mounts on the driveline. It is a bit expensive, but works better than the El Dorado calipers.
http://www.highangledriveline.com/e_brake.html
Also, I believe that Pirate4x4 has a "14 Bolt Bible" that has wheel stud info. I think that it gives part numbers to different size studs that will work in 14 bolts.
Old 05-08-2011, 12:15 AM   #15
bigd65
bigd65's Avatar
Re: 1957 4x4
Fn AWSOME thats all that can be said !!!!!!!!!!!!!!
2024 Silverado Z71 PPV
1972 Chevy Monte Carlo
2018 Buick Enclave (Wifes)
bigd65 is offline   Reply With Quote
Old 05-08-2011, 03:54 PM   #16
Sub-versive
Boss Hogg
Sub-versive's Avatar
Re: 1957 4x4
RIP El Jay
2015 Subaru Outback 3.6R Limited
2002 Chevy Trailblazer LS 2WD
Originally Posted by dammitmitchell View Post
....wear your adult diaper when you go out to play.
Originally Posted by Shane View Post
I am tard.
Do, or do not, there is no try
Sub-versive is offline   Reply With Quote
Old 05-08-2011, 03:57 PM   #17
Sub-versive
Boss Hogg
Re: 1957 4x4
Build thread???
I wanna see more!!!
RIP El Jay
I am tard.
Old 05-09-2011, 01:27 AM   #18
bartsim
Re: 1957 4x4
I found some longer studs at Napa for the corporate 14 rear. The problem i had was with the dana 60 front. I spoke to MHT FUEL SUPPORT ABOUNT THE SHORT STUD PROBLEM, THEY CALIM I ONLY NEED 5 COMPLETE TURNS TO BE SAFE, I HAVE ABOUT 10 OR 11. I WOULD LIKE THEM LONGER BUT THEY HOLD GREAT NO PROBLEMS. IT IS WORTH TH LOOK'
Old 05-09-2011, 01:30 AM   #19
bartsim
Cool Re: 1957 4x4
Originally Posted by sub-versive View Post
build thread???
I wanna see more!!!
i have a build on 1947 / 1959 take a look the thrad 1957 panle
Old 08-14-2020, 12:40 PM   #20
Apache38
Re: 1957 4x4
That's awesome!
I've had a 59 1 ton since 79. put the running gear off a 73 3/4 ton 4x4 suburban under her in 98. North of 750,000 miles. I've done construction from Austin to Fairbanks. I'm nearing retirement and I'm ready to start taking her to the next level for off road camping. Do you mind questions?
Apache38 is offline   Reply With Quote
Old 08-15-2020, 03:53 PM   #21
dennislbrooks
dennislbrooks's Avatar
Re: 1957 4x4
That is an awsome truck.
I would leave the drums as they work fine and have a very good e-brake. Spend the money on a fitech or such.
On the 67 I have disc on my 14 bolt (9.5) with Camaro calipers. All work fine except not an e-brake anymore and barely a parking brake.
I like 4 wheelers.
1942 Chevy 1/2-ton Rod, 1959 GMC 1/2 ton Fleet Step side, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T, 2018 Bolt
dennislbrooks is offline   Reply With Quote
Old 08-15-2020, 04:03 PM   #22
Re: 1957 4x4
His last post was November 2012
Originally Posted by Apache38 View Post
That's awesome!
Old 08-15-2020, 07:26 PM   #23
Apache38
Re: 1957 4x4
Same truck though!
Engine's out, front clip is off and we're finally working on it again!
59 Apache 3805 (1 ton Panel)
Stroked 350, SM465, NP-205
Corporation 14 behind Dana 60
