Old 05-03-2011, 08:24 AM   #1
68 SHORT-STEP'N
SLOW POKE
68 SHORT-STEP'N's Avatar
Can I ?
Can I replace my 68 cut-up dash with a 70 dash ? I'm pretty sure they are the same , just want to make sure . Thanks , jimmy
68 SHORT-BED-STEP-SIDE
piece by piece ,
day by day ,
I will restore this truck ,
before the 100th anniversary !!!
68 SHORT-STEP'N is offline   Reply With Quote
Old 05-03-2011, 09:17 AM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Can I ?
I believe so....the only difference I know of is AC vs non-ac dash
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 05-03-2011, 09:20 AM   #3
68 SHORT-STEP'N
SLOW POKE
Re: Can I ?
Thanks Geoff , they are both non a/c . Now I need to find someone trust-worthy enough to switch them out for me .
piece by piece ,
day by day ,
Old 05-03-2011, 09:47 AM   #4
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Can I ?
....why don't you cut it along the dash pad area, and weld it into yours??
The pad will cover the welds, so no worries if you can't weld like me
Geoff with a G
Old 05-03-2011, 09:57 AM   #5
68 SHORT-STEP'N
SLOW POKE
Re: Can I ?
The only thing I've ever used is J B Weld ! lol Thinking about a small one from Harbor Freight , mabey with a little practice .
piece by piece ,
day by day ,
Old 05-03-2011, 10:08 AM   #6
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Can I ?
check out this thread....it has a picture showing where to make the cut.....I think this is an excellent spot to practice welding cuz you can cover it up after you're done....
http://67-72chevytrucks.com/vboard/s...d.php?t=348977
Geoff with a G
Old 05-03-2011, 10:29 AM   #7
68 SHORT-STEP'N
SLOW POKE
Re: Can I ?
Just went out and looked at the un-cut dash , what happens when you get to the last holes on each end ? Continue straight across , up , down ?
piece by piece ,
day by day ,
Old 05-03-2011, 12:28 PM   #8
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Can I ?
well....I'm not sure....I'll have to look when I get home....isn't it bolted to the kick panel??.....look up under the dash and see if you can unbolt and pull off after making that cut
Geoff with a G
Old 05-03-2011, 12:57 PM   #9
68 SHORT-STEP'N
SLOW POKE
Re: Can I ?
I see now ! I'm a little slow sometimes . lol You continue the same line till you get to the end . I did'nt think the dash pad went all the way over & tuck down by the windshield post . Thanks for all your help Geoff . I think I'll give it a try when I get to that point .
piece by piece ,
day by day ,
Old 05-03-2011, 01:10 PM   #10
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Can I ?
we need a how-to on it....so post up a detailed how-to with pictures when you do it!!!
Geoff with a G
