Old 05-03-2011, 09:36 AM   #1
candyx
candyx's Avatar
Cross Over Pipe
Anyone run a cross over pipe or X-pipe on their exhaust system,i have a 57 and theres like no space to do that without having the pipe directly under the transmission.I'm running a crate motor 350/330 and just wondering if its even nessary to have the cross over pipe at all?
candyx is offline   Reply With Quote
Old 05-03-2011, 10:33 AM   #2
pro1955
pro1955's Avatar
Re: Cross Over Pipe
I usually put the crossover behind the trans. at the front of the driveshaft. You don't need one it's up to you, it mellows out the exhaust note. If you use flowmaster type muffles use a crossover not an X pipe, Flowmaster tech. told me that.
Truck's just for the fun of it.
pro1955 is offline   Reply With Quote
Old 05-03-2011, 11:42 AM   #3
candyx
candyx's Avatar
Re: Cross Over Pipe
That would make it easier to use just a cross over pipe and at the front of the drive shaft would be the prefect spot,thanks.
Old 05-03-2011, 09:44 PM   #4
solidaxel
solidaxel's Avatar
Re: Cross Over Pipe
I will second that!
I did that on my 53 and it made a great difference in sound and low end power. go for it
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 05-03-2011, 10:03 PM   #5
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Cross Over Pipe
I went behind the trans on mine. I used a thermal wrap on it to protect the joint.
dwcsr is offline   Reply With Quote
