05-03-2011, 09:49 AM | #1 |
67 drop spindles
I have a 67 c-10 with 6 lug drum brakes, my question is if i can get a 2.5 drop spindle that will convert my truck to a 5 lug disk is there a reason to change to the 73-87 control arms and crossmember? any help would be greatly appreciated.
05-03-2011, 10:01 AM | #2 |
Project Junkie! Fishing Poor!!
Re: 67 drop spindles
No need to change those parts as long as you buy 63 to 70 drop spindles. You will need to do something with your brakes though, because you are going from drum/drum to drum/disk. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
05-03-2011, 10:07 AM | #3 |
thanks for the info what disks / calipers would i need to use? would it depend on the spindle company
05-03-2011, 11:05 AM | #4 |
Active Member
Your best bet is to get a conversion kit. Around $650 and up depending on manufacturer and what is in it.
If you're serious about the conversion, you can also scrounge a 71 and newer front disc brake setup complete. Sometimes you can find them in salvage yards or check the parts for sale forum on this site. |
05-03-2011, 12:10 PM | #5 | |
67-72 parts collector,…
I always purchase '73 rotors, bearings and calipers. It saves alot of confusing at the parts store. (especially if you tell them your truck is a '67). Just tell them your truck is a '73.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 05-03-2011 at 12:10 PM. |
05-03-2011, 12:25 PM | #6 |
thanks for the info i plan on bagging the truck so i was wondering why most guys went with the 73-87 front suspension parts
05-03-2011, 03:11 PM | #7 |
$209 for the spindle
$219 for the brake part kit $139 for manual master cylinder CPP 4 bags and metal plates for the front at suicide doors. Doing the same thing right now on a 67 C10 Just need the dust sheilds and hoses from your NAPA
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
05-03-2011, 03:21 PM | #8 | |
The 71-72 calipers are higher priced than the 73-87 calipers. I like using 73-78 calipers because they use a 7/16-20 banjo bolt on the rubber brake hose connection. I believe the 79-87 calipers use a 10mm metric bolt. Since you are using 63-70 conversion spindles,... you will be able to use stock '67 balljoints and tie rod ends. It makes for a very simple install using these conversion spindles.
