Old 05-03-2011, 10:21 AM   #1
WHITE-NOISE
WHITE-NOISE's Avatar
brake swaping questions, need some help!
i am currently building a 68 k20, started with a bare frame and right now im working on the brake system. i am changing from manual 4 wheel drum brakes, to 4 wheel disk and hydraboost!, currently i have all the hydraboost done and plumbed but on my master cylender i am unsure which reservoir controls front and rear, im pretty sure the m/c i have is for disk/drum brakes as it has to different size reservoirs, does it really matter which one goes where now?
WHITE-NOISE is offline   Reply With Quote
Old 05-08-2011, 09:27 PM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: brake swaping questions, need some help!
ttt
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 05-08-2011, 09:31 PM   #3
Stricklinator
Stricklinator's Avatar
In my 69 C20, the reservoir closest to the firewall is for the rear brakes. The only reason I know is because when I bought it one of the rear lines was rusted through and so it ran empty.
1969 C/20, 307, 4-speed, rusty with manual steering and brakes!
Stricklinator is offline   Reply With Quote
Old 05-17-2013, 03:22 AM   #4
68 TT
Still plays with trucks
68 TT's Avatar
Half ton flips the location of the front brake reservoir position relative to 3/4-ton master cylinders so you have to know what application it came from to know for sure which end is the front brake reservoir.
On 3/4-tons the front of the master is for the rear brakes and on 1/2-tons it is the rear of the master for the rear brakes.
The fitting coming out of the master cylinder is a larger size for the rear brakes. Check out your stock plumbing to see which fitting size goes to the rear to know for sure which one you have on there.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
Old 05-17-2013, 03:44 AM   #5
SS Tim
SS Tim's Avatar
What makes you think your disc/drum master has enough fluid volume for a disc/dics application? Start by identifying your master and determine if it is big enough and I'm sure the proper ports will become apparent.
As far as best practice plumbing I'd model it after the stock Hydro Boost truck your parts are from if it was a disc/disc truck.
SS Tim is offline   Reply With Quote
Old 05-17-2013, 12:29 PM   #6
nlped
nlped's Avatar
I'd even consider using the Hydroboost M/C that's designed for this disc/disc system. Then you know you have that part correct...& the luxury of a newer, easier to locate part... Just my .02
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 05-17-2013, 12:51 PM   #7
tony58
The large reservoir is for the front disc brakes. If you have a disc/drum master you can use it on disc/disc, just refill the small reservoir down the road as the pads wear, it'll take quite some time to need refilling as the rear pads don't wear very quickly.
tony58 is offline   Reply With Quote
