05-03-2011, 10:23 AM | #1 |
Heater control valve
Hey everyone i have a question regarding the heater system, Is there suppose to be a heater control valve going into heater in the cab? My truck is a 63 with the recirculating heater system, as I am putting the truck back together I noticed that heater core will always be hot no way to isolate it during the summer months, don't need any additional heat here in Texas during the summer I could not find anything in the manual nor the net and i don't know if the PO removed it. So any help would be appreciated Thanks
Dennis N. USN Ret. Patriotism is your conviction that this country is superior to all other countries because you were born in it. |
05-03-2011, 12:25 PM | #2 |
Re: Heater control valve
I use a manual shut-off in the hose.
05-03-2011, 01:38 PM | #3 |
1965 Chevy C10, 2005 4.8L/4l60
I use a shut off valve that I turn off under the hood. I did have one that was sort of manual, I used my choke cable and hooked it to a valve I got from Old Air Products that would shut the flow down, it still seeped through and hindered my AC cooling, so I went back to the manual valve.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! Last edited by Clyde65; 05-03-2011 at 01:38 PM. |
05-03-2011, 04:09 PM | #4 |
make sure you drill a bleed hole in the thermostat if you use a valve or you wont have water circulating under thermostat........
05-04-2011, 08:46 AM | #5 |
Cool, I appreciate everyone's help on this Thanks again
