Old 05-03-2011, 11:53 AM   #1
DetroitIron
DetroitIron's Avatar
Compression Check with Carb. Off?
I have my quadrajet off my 350 for a rebuild and want to pull all the plugs and do a compression check on the engine. Any issue with doing a compression check while the carb. is off? I didn't think so as I've alway been told to hold the carb at WOT for compression checking. Just wanted to check this would not give me inaccurate compression readings. I will need to direct the gas line supply into a bucket or something to keep the fuel pump from pumping gas out on top of the intake. Thanks Guys.
_______________________________________________
1985 Chevy Scottsdale K20 350 with 700R4 running 3.42 gearing aka "The Honey Badger"
1993 Silverado C3500 Ext. Cab Dually 6.5 turbo diesel
DetroitIron is offline   Reply With Quote
Old 05-03-2011, 12:30 PM   #2
BIG V
Re: Compression Check with Carb. Off?
dont see a problem with it??
1991 Chevy suburban 3/4 ton 4x 4:56 and pulls great
1979 Chevy 1/2 ton long bed diesel
1974 Chevy crew cab short bed 3/4 ton 4x4 project
1991 Chevy suburban 2wd
1984 Chevy suburban 3/4 ton 4x 6.5 detroit with turbo
1961 Chevy pickup 1/2 ton 2wd
1975 gmc crew cab short bed 2wd
BIG V is offline   Reply With Quote
Old 05-03-2011, 12:31 PM   #3
parrisc19844x4_468
parrisc19844x4_468's Avatar
You better hope not.
2017 Silverado LTZ 6.2
1984 Scottsdale K10 - 468 700r 4x4 lwb
1978 GMC Sierra Grande K15 350 Soond to be 406 th350 4x4 swb
1968 GMC 20 305 V6 good ole wood hauler.
Good Fences make good neighbors
parrisc19844x4_468 is offline   Reply With Quote
Old 05-03-2011, 01:26 PM   #4
sumran
sumran's Avatar
You will get more accurate compression results with the carb and exhaust removed. It is not worth the trouble to remove the exhaust. You are only looking for consistency and approximate value.
If you have a mechanical fuel pump I would suggest removing and plugging the incoming fuel line to the pump rather than trying to catch the gas. If you have an electric fuel pump, pull the fuse or disconnect the power to the pump.
Randy Summers
Never brake in the learning curve!
1984 GMC Sierra project truck http://67-72chevytrucks.com/vboard/s...d.php?t=446737
sumran is offline   Reply With Quote
