1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
anyone got a 6 guage dash template?
I would like one so I can cut my dash out of wood or maybe aluminum.
Thanks guys!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Re: anyone got a 6 guage dash template?
I'm gonna do the same thing outta walnut, I could use one also
1978 GMC Jimmy, 400, th350, np203 with part time conversion, Fibrecraft popup camper, soon to get a 14 bolt/d44 swap 2001 Yukon XL2500, 6.0, 4L85E, 4x4, family truckster |
meowMEOWmeowMEOW
whole dash? or do you mean just the face of the instrument panel?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Face of instrument panel for aftermarket gauges. I just dont want to spend $150.00 on a billet one, besides that would go well in my truck.
If it is for a 65 what i did for a 66 i had was to take the glass out of your cluster and trace it on to a thin peice of wood.use the guages you want and trace and then cut with a hole saw.you might have to trim a little then stain,will look great
![]() Join Date: Oct 2006
On my 60' I used masonite board to mock my dash insert up. I coverd it with some chrome vinyl sign decal material. It was onlly going to be temporary , just a pattern but that was 5 years ago and it has held up fine and was real easy to fab up.
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " Last edited by slepysal; 05-03-2011 at 05:39 PM. |
I currently have a wood insert my dad made, it is for 5 gauges, decided to put a tach in, soooo..
Can you use yours to make a new layout ?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
Cardboard or masonite works well. I used the existing clear dash lense.
I taped over it w/blue painters tape & used poster-board circle templates to get an idea of where I wanted things. The circle templates were indexed vertically/horizontally to put reference marks (they help easily locate the C/L of where to drill).
I did what someone mentioned. I took the glass/plastic face and took it to tap plastics. Had them cut it the the shape of the glass. Then I took it home and made a template of where the gauges were going to go and busted out the hole saw.
this is my DD, so I dont want to have it down for anytime. I am going to see if I or my dad has an old dash surround and maybe I can make it our of smoked plexiglass.
#12 | |
I made everything work off the template so you could do the same to determine your layout dimensions w/o having extended downtime.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 05-04-2011 at 10:24 PM. |
#13 |
Carefull cutting the plexiglass it cracks easy. I was able to make mine in one afternoon . No real down time
#14 |
x2. Cut smaller holes & file to fit.
#15 |
What about the lens? I have seen replacements, but they are stock. I want the stock look with black numbers and letters. Is there a vinyl kit or something? I could take the glass out and have one made, but it would be nice to do it myself.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
#16 |
#17 |
But Found Her 25yrs Later!
Did anyone ever locate a template?
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
#18 |
I have a panel that I'll be taking apart in the next few weeks if your not in a huge rush..I can trace it for you then.
65Gregg Blue long bed White TBSS 61 Impala “The two most important days in your life are the day you are born and the day you find out why.” Mark Twain Last edited by 65Gregg; 07-25-2012 at 01:36 PM. Reason: I can't spell |
#19 | |
#20 |
meowMEOWmeowMEOW
I have a stainless piece cut to fit the bezel with a center tach hole punched; I made a couple and only used one, so this ones left over if anyone wants to have the hard part done already
#21 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
I could probably draw one up in autoCAD. Are those gauges you bought 2-1/16" diameter?
#22 |
I was also thinking of drawing one up in cad.
One thought I had was to scan mine on a flatbed scanner, and then import the image into acad.
#23 |
60-66 Nut
Yeah, if you have a flatbed scanner big enough, that would be an easy way to get a basic outline to start with.
#24 |
Went searching for dash gauge template thread and forgot I was involved in this one.
Gotta scan mine and trace it in CAD. . In the meantime, has anyone have different template layouts for various guage layouts?
#25 |
Here's a link to a short thread I did when I made mine. It has a few good pics of my layout. https://67-72chevytrucks.com/vboard/...d.php?t=810650
