Old 03-27-2003, 01:14 AM   #1
Nova_Cobra64
Nova_Cobra64's Avatar
No Head Lights
My truck is in storage right now and I have been doing work to it. I replaced my headlight switch while I had my instrument panel out. Now I have no headlights. I have tried grounding the dimmer switch and checking the fuses to no avail.
Anything I could look for?
Nova_Cobra64 is offline   Reply With Quote
Old 03-27-2003, 11:03 AM   #2
Nova_Cobra64
I guess I should have mentioned that it is a 69 GMC.
Is there anything in the headlight wiring that is failure prone for some reason?
With my luck I will end up having to spend an afternoon with a test light.
Old 03-27-2003, 12:02 PM   #3
jhow66
jhow66's Avatar
Sounds like your dimmer switch. Turn headlights on and pull connector off dimmer. Jump from blue wire to the green or tan wire-if they burn dimmer bad or hung in between.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
