Old 05-03-2011, 06:21 PM   #1
Mikedub82
Mikedub82's Avatar
Alternator amp/ air compressors
Just realized the early 70's & 80's alternators are only 40/50/60 amp alternators. I am going to run 2 viair 444c compressors that are 30 amp draw each. I have a red top optima battery. Will the alternator be enough or will I have to find a bigger one.
Get Low
Mikedub82 is offline   Reply With Quote
Old 05-04-2011, 10:51 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Alternator amp/ air compressors
If you are running two compressors in unison, I think you should update your alternator. I would consider any of the 90+ amp units on the market.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-04-2011, 01:18 PM   #3
Mikedub82
Mikedub82's Avatar
I called a friend of mine at an alternator shop. If any of you guys wanted to up grade to a bigger alternator. The part # that any parts store could cross would be 7294. It comes 94 amp, but your local alternator shop could get you up to 150 amps. This alterntor should be factory for 87-90 chevy trucks. I has to be the one with the solid plastic fan on the front. You learn something new everyday!
Get Low
Old 05-04-2011, 01:42 PM   #4
SCOTI
SCOTI's Avatar
Attachment 741504
The HO 305 Camaros (82-8x) typically also have an interchangeable alt w/higher amps.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
