Old 05-03-2011, 07:57 PM   #1
ncgamedog
which cab mounts for 68 2wd to 72 4wd?
Ok I'm starting to get my parts list together for a big order on our project. The project is a 68 2wd LWB PU going on a 72 4wd LWB frame. Should I order cab/body mounts for the 68 or 72? AND should I get 2wd or 4wd mounts?
I have been told to get the 72 mounts, but I noticed there is a difference between the 2wd and 4wd.
BTW: LMC has ZERO tech assistance and I find that staggering! Is there a better vendor to deal with?
ncgamedog is offline   Reply With Quote
Old 05-06-2011, 04:30 AM   #2
1malo68
1malo68's Avatar
Re: which cab mounts for 68 2wd to 72 4wd?
I would say get the mounts that match your frame. Cabs and beds should be the same. My $.02
1968 K10/30
Frame Off Project "Overkill"
My 5 year, $30,000.00 toy
1malo68 is offline   Reply With Quote
Old 05-06-2011, 08:59 PM   #3
coops714x4
coops714x4's Avatar
you will need the 4x4 mounts to fit the frame if you compare the frames you can see the difference in the rear cab mounts
1971 K20, Coop's beast (project)
1972 C30 wrecker, "Big Ernest" (SOLD)
1975 K5 Blazer (wife's toy) she got it in the divorce
2014 Street Glide Special
1983 K20 Big Block, auto (work horse)
coops714x4 is offline   Reply With Quote
Old 05-15-2011, 07:43 PM   #4
liftlawssuck
liftlawssuck's Avatar
I put a 2wd cab on my 4wd frame and got mounts for a 4wd. If you get urethane mounts you have to shim the front of the cab up quite a bit. I don't know why but everyone I've installed I had to shim up. Cabs are the same. Frame mounts are different.
liftlawssuck is offline   Reply With Quote
