05-03-2011, 08:25 PM | #1 |
Steering stops
Going to use '73+ drop spindles on my "68. Can you use '71-'72 lower a-arms with the '73+ spindles without having any steering stop problems?
Thanks for you help. |
05-04-2011, 12:19 PM | #2 | |
67-72 parts collector,…
Re: Steering stops
I have done it before. You will need to change the upper ball joint,... if,... your upper a-arms are from a '71 also. The '71 lower ball joint will work fine with your 73-87 spindle.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 05-04-2011 at 12:21 PM. |
