05-03-2011, 08:54 PM | #1 |
Roadtrip!
Trans O.D-I.D.?
Went to the scrapyard today and was walking out when i saw a ford ranger with a mid 70s chevy gate laying in the bed. Gate looked good so i grabbed it. Under the gate was this trans. I think it is a 67 overdrive setup, but just wondering if anyone can confirm? The tailshaft has a slight bend in it... Bummer... i still grabbed it.
Numbers on the case are 3858986 C 15 7 Thanks.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
05-03-2011, 09:39 PM | #2 |
Member #1049
Re: Trans O.D-I.D.?
That is a Saginaw all syncro 3spd OD. I think they started using them in 68, (but could be off by a year)
05-03-2011, 10:54 PM | #3 |
Roadtrip!
Re: Trans O.D-I.D.?
Thanks for the info mark. The date code looks like march of 67. Is this what would be used in the 67-69 pickups?
05-03-2011, 11:08 PM | #4 |
Grandpa in the rustmobile...
Re: Trans O.D-I.D.?
So explain to me how this works exactly, and is it on the SPID? Is there a 4th gear or the 3rd is just super high?
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
05-03-2011, 11:31 PM | #5 |
Roadtrip!
Re: Trans O.D-I.D.?
I have a 67 shortbed that has it listed on the spid. I am not sure of the exact setup, but there is an overdrive lever under the dash to pull out and that would engage the overdrive. On a 67 ford i used to drive if the overdrive knob was out you just let off the gas at 32 mph or faster and it would shift into OD like an auto. I assume this would be similar.
05-03-2011, 11:37 PM | #6 |
Member #1049
Re: Trans O.D-I.D.?
05-03-2011, 11:57 PM | #7 |
Roadtrip!
Re: Trans O.D-I.D.?
I wasn't aware of these after 69. I know they didn't come behind any "bigger" or performance engines. So the car and truck ones are the same trans?
05-04-2011, 12:22 AM | #8 |
Member #1049
Re: Trans O.D-I.D.?
After a bit of research it appears they only used it from 66-69 in the trucks, and my Hollander interchange manual lists a different number for the passenger car version, I guess the one in my 68 Chevelle was incorrect, (it looked identical to the truck version) Hmmmmmm
05-04-2011, 12:27 AM | #9 |
Member #1049
Re: Trans O.D-I.D.?
More research.. the Chevelle version looks identical
http://www.chevellecd.net/6667cd/66/...ion/manual.htm |
05-31-2011, 11:14 AM | #10 |
Re: Trans O.D-I.D.?
Old thread and I don't know if this helps but...a friend just pulled his Dad's old truck from beside their barn. I think it was a 70, not sure. It was a CST and he thinks it had a 307 (v8 for sure). It had the overdrive on the SPID as well as the Tachometer. Under the dash was a fairly large black handle labeled overdrive. Was a three on the tree. My friend recalled when you got it up to speed in third, you put in the clutch and pulled out the handle, then released the clutch.
05-31-2011, 01:29 PM | #11 |
Re: Trans O.D-I.D.?
i pulled one of these from a 1967 chevelle station wagon...
looks just like the one pictured..
05-31-2011, 02:32 PM | #12 |
Re: Trans O.D-I.D.?
Are these transmissions tough to get refurbished?
