Old 05-04-2011, 01:36 PM   #1
R.R
How do you
set the timing on a 1995 chevy truck?
R.R is offline   Reply With Quote
Old 05-04-2011, 03:07 PM   #2
WestButteTruck
Kung Fu Master
WestButteTruck's Avatar
Re: How do you
With a timing light....
O.K., all kidding aside, to set the timing you must unplug the set timing connector, which is a single Tan wire with a black stripe/tracer on it. On some years the set timing wire is tan with a white stripe/tracer.
On your 95, I'm thinking it's located under the glove box inside the cab. Should be a single wire with a connector. Unplug, then set your base timing to "0", then plug wire back in. This will probably set a code you will need to clear out. Hope this helps.
72 GMC SuperCustom 4x4
1972 Chevrolet Cheyenne Super 4x4
WestButteTruck is offline   Reply With Quote
Old 05-04-2011, 03:19 PM   #3
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: How do you
R.R., do you have a service manual like a Chilton or Haynes? It details exactly how to do it.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 05-04-2011, 03:24 PM   #4
R.R
Re: How do you
I can get the manual from a friend, thanks for the replies I will try it this afternoon.
Old 05-05-2011, 07:46 AM   #5
R.R
Re: How do you
Ok I set the timing as the book said. It still backfires when driving. and gets where it will not run at all. Any suggestion!
Old 05-05-2011, 11:35 AM   #6
WestButteTruck
Kung Fu Master
Re: How do you
What all did you do to it before you decided to mess with the timing?
Do you have any plug wires messed up?
Old 05-05-2011, 11:38 AM   #7
R.R
Re: How do you
Had to pull the distributor to install a pickup coil. It runs fine until it gets to normal operating temperature.
Old 05-06-2011, 07:48 AM   #8
R.R
Re: How do you
Where should the timing mark be after setting to "0" and the wire plugged back in?
Old 05-06-2011, 08:33 PM   #9
scotts62
One day...
scotts62's Avatar
Re: How do you
Unplug the wire set it to 0 and plug it back in and the computer will do the rest.
Scott
93 crew cab build
Project 62
