Old 03-27-2003, 10:20 AM   #1
RCOMBS
Question wires for alternator and battery ground wire
Putting back together 72-C10 W/ 350. Need to know where the ground wire for battery is bolted on? and also the 2 wires on the back of the alternator, does the red wire go on the bolt or the stud? Thanks in advance.
RCOMBS is offline   Reply With Quote
Old 03-27-2003, 10:45 AM   #2
Randy70C-10
Randy70C-10's Avatar
You should ground the battery to the engine block, and the engine block to the chassis. The red alternator wire goes to the large stud with the plastic donut around it.
Randy70C-10 is offline   Reply With Quote
Old 03-27-2003, 10:57 AM   #3
RCOMBS
I guess what I am asking is do you know where on the block is the original place to bolt this ground wire to. and on the alternator i have there is a stud on the back at the bottom and there is a bolt on the back at the top. Which one does the red wire go to. don't mean to sound so stupid just want to make sure it is right.
Old 03-27-2003, 11:12 AM   #4
Yukon Jack
Post Whore
Yukon Jack's Avatar
On my 69's 307 the ground wire from the battery went to the front of the engine block, passenger side. I will look for a pic.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 03-27-2003, 11:16 AM   #5
Yukon Jack
Post Whore
Yukon Jack's Avatar
Here's a pic while I was pulling the engine. The ground wire is right below the valve cover - already disconnected from the battery.
Old 03-27-2003, 02:14 PM   #6
Blue Beard
Blue Beard's Avatar
my 70 is grounded to the right head as well.............
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 03-27-2003, 08:51 PM   #7
matt_field
matt_field's Avatar
what if you have no holes in your heads?
1971 k5 blazer 80k mike survivor
1972 3/4 ton 4wd Cummins 12v
1967 swb 2wd 427bbc
1968 4wd shortbox
1971 Cheyenne swb k10 unrestored
1971 Cheyenne super 40k 402bb survivor
1967 Chevy k10 (first truck)
1968 L78 camaro survivor 18k miles
1969 z28 survivor 60k miles
1969 z28 survivor 39k miles
1969 z28 rs survivor 80k miles
matt_field is offline   Reply With Quote
Old 03-27-2003, 09:19 PM   #8
6869704X4
There is a couple of holes on the front of the block near the fuel pump. You know one of them is the one that goes through to the fuel pump shaft.
The more I learn about women, the more I love my truck.
6869704X4 is offline   Reply With Quote
Old 03-28-2003, 01:39 PM   #9
Blue68
Blue68's Avatar
Water pump bolt for the ground wire. The stud on the alternator back is your juice. I have a '98 so my alternator wires are a little different now and can't remember the older style setup.
http://home.comcast.net/~r.landrum/w...tos.html-.html
'68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades.
Blue68 is offline   Reply With Quote
Old 03-29-2003, 11:39 AM   #10
6869704X4
Another place is the thermostat housing bolt. When I switched to long water pump I put mine there along with the alternator bracket.
Old 03-29-2003, 11:55 AM   #11
pierce
pierce's Avatar
On the alt there's 2 studs, the top is for the red wire and the bottom (smaller) is for the black ground wire.
69 GMC 1 Ton Longhorn
37 Chevy Coupe
pierce is offline   Reply With Quote
