Old 05-05-2011, 10:04 AM   #1
ges55
BLACK SATIN
ges55's Avatar
different speed blower motors
I have 2 67s, one 3/4 ton & one 1/2 ton. The high blower setting on the 1/2 ton is much higher than the one on the 3/4 ton. Is that what deluxe air heater means?
Thanks in advance for the info.
67 C10 Fleetside LWB-283, 3 on the tree,power assisted steering, father-in-law bought it new
67 C20 Fleetside LWB-'85 305 V8 (original was 250 6 cyl), Holley 600 carb, full length Hedman headers, dual exhaust behind the back wheels, 4 spd , manual steering
85 C10 Silverado- 305ci
ges55 is offline   Reply With Quote
Old 05-05-2011, 10:45 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: different speed blower motors
is the 1/2 ton an a/c truck and the 3/4 ton non a/c?
Old 05-06-2011, 08:18 AM   #3
ges55
BLACK SATIN
ges55's Avatar
No, they are both non-A/C.
Old 05-06-2011, 10:35 AM   #4
turp mcspray
turp mcspray's Avatar
I always prefer to run the a/c blower, as it moves more air. Maybe someone has swapped one into yours.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 05-06-2011, 09:33 PM   #5
Longhorn Man
probably one has more resistance in the power, or more resistance in the ground, or one has a 44 year old blower and the other has a newer one...
Therre should be no reason as far as design though.
