Looking for a measurement
Can someone give me the width of the bed strips. I'm getting ready to route the grooves for my bed floor.
Re: Looking for a measurement
Can't help with the strip width since my truck didn't come with any, but here's a link that might help. I am planning on making my own also when I get that far.
http://www.chevytrucks.org/tech/bedwood.htm |
this is where it's at IMO.
http://www.gmcpauls.com/47-72_BedWood_Info.htm you don't really need a router, you can do it with a table saw and a Dado blade, or even with a 1/8" kerf blade if you've got a little patience. See the little diagram. Last edited by tmoble; 05-05-2011 at 04:20 PM. |
a table saw was my tool of choice. fast and easy
'57 Chevy Pickup '56 GMC LCF Cummins '38 Chrysler Royal '57 2wd change http://67-72chevytrucks.com/vboard/s...light=speedway Last edited by blackdiesel; 05-05-2011 at 10:49 PM. |
Task force strip. Its a bit rusty but intact, measures right at 1.5 iches, that is 1 1/2.
And if you go to that GMC pauls site and scroll down to the picture that shows "D" and "C" the dimensions add up to .75 and since they butt together that makes 1.5, just go by that picture. Last edited by dicer; 05-05-2011 at 10:42 PM. |
~~~~ x 3 ~~~~
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
#7 | |
'57 Chevy Pickup '56 GMC LCF Cummins '38 Chrysler Royal '57 2wd change http://67-72chevytrucks.com/vboard/s...light=speedway |
Don't know, my boards were a mess. The strip does measure 1.5 iches wide. I was just commenting on the drawing on that other site.
Okay after looking at the old wood piece, the wood just touches the bolt barely, so if its a 5/16 bolt, thats 19/32 on each side. |
you need a little room across the grain, that's the way wood expands. it doesn't expand much the long way, along the grain. you need at least 1/16' inch on either side of the bolts.
I din't mean for everyone to get into a debate. I'm just using some finish grade plywood. The 1 1/2 measurment is what I needed. Thanks to everyone. Heres the pic of what I got done.
Here it is.
#13 |
Nobody got my joke. so sad
#14 |
I was planning on doing the exact same thing. what was the width of plywood that you used? I cant find a piece wide of enough, std is 48" x 96". I need a piece around 50 inches wide. Please some pix once you get your strips in. BTW the color is a great choice. Are you going to paint your strips or go with chrome?
thanks
"Get Busy Living or Get Busy Dying" 1970 P10 Stepvan Last edited by rhodog77; 05-08-2011 at 12:18 AM. |
#15 |
It is a standerd 4x8 sheet of ply. My bed is 50" across but after bagging it I needed to raise the floor and reinforce the bed sides. I used 1 1/2" uni strut bolted to the bed sides. This brought the measuement to 47". I used some 3/4x 3 pressure treated runners to fit into the strut. My floor will bolt to the runners allowing me to slide my floor out if I ever need to work on my suspension or batterys. I'll posts some pics later.
#16 |
#17 |
thanks for the info. cant wait to see some pix.
"Get Busy Living or Get Busy Dying" 1970 P10 Stepvan |
#18 |
Heres some pics of today
#19 |
Sorry lets try this.
#20 |
thanks so much for posting the pix. that really helps me picture what i was thinking. Im think Im going to call my metal shop and price some 1" x 2" c channel that is 3/4" deep ( or whatever thickness my plywood sheet is). That way I can slid the sheet into the channel and have it flush. Im figuring I can weld the channel from the underside to the bed and then run my cross sills underneath it.
thanks again!!!
"Get Busy Living or Get Busy Dying" 1970 P10 Stepvan Last edited by rhodog77; 05-08-2011 at 09:34 PM. |
