05-05-2011, 04:46 PM | #1 |
Any advise for the 69 GMC eyebrow trim
I'm putting the 69 back together with fresh paint, everything went surprisingly smooth (hood, fenders, Doors, etc.) until I got to the eyebrow trim. I had to buy aftermarket trim peices and they either line up perfect with the grill and have huge gaps around the fender or line up with the fender nicely but are way out of whack with the grill. Is there a trick to getting these things to fit, they look the same as the old ones and the old ones don't want to line up either. Any advise would be appreciated.
05-08-2011, 09:24 PM | #2 |
Restoration Virgin!
Re: Any advise for the 69 GMC eyebrow trim
ttt
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
05-08-2011, 11:19 PM | #3 |
I recall having the same headache. I messed with it for a couple of days. And to get anywhere close required some bending/ destorting of those clamp type brackets till I finally give up. Ended up not perfect but as close as I could get it. Overall it was a pain to mess with but don't look too bad, unless you really study it hard. Those clamps are tuff don't be scared to remove them and tap them to where you think they need to be.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
05-09-2011, 05:46 AM | #4 |
My son got his eybrows to line up on his 69 GMC by using the original clips and doing some fitting.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
05-18-2011, 12:02 PM | #5 |
I got it as close as I could
