Old 05-05-2011, 07:29 PM   #1
slepysal
slepysal's Avatar
yet another booster question
Due to space issues, how well would a single 8" work on a disc/drum set up?
I have a L6 250 with clifford intake and clearance is an issue.
So should I use the 8" or just run it manual. any Tips?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 05-05-2011, 08:21 PM   #2
bama63
bama63's Avatar
Re: yet another booster question
lakeroadster just covered in this post http://67-72chevytrucks.com/vboard/s...d.php?t=462949 hope this sheds some light it did for me lol
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
Old 05-06-2011, 01:36 AM   #3
slepysal
slepysal's Avatar
yea I seen that thred, didnt want to hijack it, and mine is a single not a dual thanks
Old 05-06-2011, 08:08 AM   #4
lakeroadster
I would suggest hooking a vacuum gage to your motor to see what kind of vacuum you have. Then armed with your vacuum information call this place and ask them. Brakes are their specialty and they will steer you in the right direction: http://www.chtopping.com/Home/index.html
Let us know what you find out. I am betting they will tell you if you are going to use a booster, and can't use a big 11" single, that you should use a dual, 'cause the single 8" isn't enough diaphragm area. And that a manual set-up would be better than a single 8", again 'cause the single 8" isn't enough diaphragm area.
If you don't have enough area, based on your vacuum signal, a power brake set-up can be worse than no booster at all. If you have ever tried to stop a boosted brake vehicle with the motor not running you know what I am referring to.
Hope this helps.
John
lakeroadster is offline   Reply With Quote
