05-05-2011, 08:04 PM | #1 |
HELP! driveline with bags!
i keep brake my carrier bearing mout because of the angle of my driveline since i bagged the truck. what are all you bagged guys doing about your drivelines? one piece? slip joint?? please help! thanks.
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB |
05-05-2011, 08:18 PM | #2 |
VA72C10
Re: HELP! driveline with bags!
I know on my lwb I flipped the carrier bearing mount to make the angle better. Not sure it would help on a swb or not....
...bump for you....
Looking for a 67-72 swb or blazer project in or around VA. |
05-05-2011, 08:21 PM | #3 |
so you just mounted it on the bottom of the x member?
05-05-2011, 08:24 PM | #4 |
VA72C10
yep, just drilled out the rivets and flipped it from mounting at the top to mounting at the bottom....making sure to center it when re-installing...
05-05-2011, 08:27 PM | #5 |
the boat guy
there shouldn't be any load on a carrier bearing except to hold the shaft up. If the rear shaft doesnt have a slip in it it can cause issues, no modern 2 piece driveline doesn't have a slip in the rear shaft. Are you putting so much angle on the 2nd shaft that the ujoint in the middle is binding and pushing the carrier bearing up? Ujoints are only designed to operate at a maximum of 3° they will physically function but will cause vibration issues.
05-05-2011, 08:37 PM | #6 |
mine doesnt have a slip joint and its the original driveline, yes it is pushing on it and braking the mount.
05-05-2011, 10:59 PM | #7 | |
Don't guess at it, buy a protractor (about 10 bucks at Home Depot or Lowe's) and check the angles. Once you know what the angles are you will be able to figure out what you have to to fix it correctly the first time. Nothing worse than spitting a driveline out in the street when you are all dressed up in your going out to dinner clothes. There is real good information at the Spicer /Dana website for setting multi-shaft driveline angles. I would have include the link but I am stupid like that. |
05-05-2011, 11:53 PM | #8 |
I've been wanting to flip my carrier bearing as well con someone post befor and after pics thanks
Some progress is better then no progress |
05-11-2011, 07:37 PM | #9 |
yes can someone post a pic of the bearing flipped? i was thinking of using a porterbuild x member and a billit bearing flipped
05-11-2011, 07:55 PM | #10 |
VA72C10
Here you go...
before after and the stance of the truck..
Looking for a 67-72 swb or blazer project in or around VA. Last edited by VA72C10; 05-11-2011 at 07:56 PM. |
