new guy here This place is is BAD @$$
I need some help I trying to swap out the brake booster on my 67 what I dont know would my old proportioning valve work on a newer booster and would a newer booster work on my truck I see some booster with two small rods at the end the one i have has one longer rod only
Any help would be great ![]() |
Re: new guy here This place is is BAD @$$
I think the one you are talking about with 2 rods may be a hydroboost. The standard vac. can I put on mine was a single rod.
As long as you are still using the same master cylinder (and not changing from drums to discs), you can use all the original parts, including the prop. valve. If you are going from 4 drums to 2 disc/2 drum, you would need the correct prop. valve. There is a step by step on here somewhere (check the FAQ section). I did the swap on mine. Took less than an hour. One hint - take off the mc/booster bolts and move it away from the firewall before you try to take off the brake pedal linkage. This will drop the pedal arm down far enough to remove the bolt that connects the link to the pedal. Otherwise, you have to drop the steering column. The newer booster, I couldn't tell you. Depends on the mounting and size. Anything from the 67-72 range should bolt straight in. Welcome to the board. More info than you can ever use - but fun to try.
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress Last edited by dmack91; 05-06-2011 at 08:38 PM. |
whats going on man!? good luck with ur project need to post some pics im the guy that contacted u off craigslist yesterday
Tot Roddin'
Welcome to the board 67Jhdz!
I have moved your thread to the 67-72 message board so we can try to get you some additional reponses to your question. Take a look around this place and you will be amazed with the information that's available. ![]() Cheers! Nate
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
Here is the install FAQ I used. Pretty straightforward.
http://67-72chevytrucks.com/vboard/s...d.php?t=221598
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress |
Big Red - Now its a SWB!
Welcome to the site, there is some very knowledgeable people on here and I'm sure they will help you out.
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
Welcome to the board,hey from N.C.Keep on Truckin'' :metaL:
My Truck: 2.5 drop front, 4 & 5/8 in rear, 350cubic in. been bored .60 over, 700r4 (soon), 3 speed (on tree for now).rims & tires size,15x8 ralleys 5 on 5,P275/60R15. Members I have met: Pickupman, 1972 Super Cheyenne, Stepside,Chis Mc Bride. tsnow67,joel.e, ![]() |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Welcome from southern oregon..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Re:Thanks
thanks for all the help
this website makes my day at work go by so fast lol |
