05-06-2011, 11:35 AM | #1 |
airport find not sure of year.
hi All, I see this truck a lot and every time I taxi by it in Toronto I wonder the year and restorability.....And thought you all might enjoy a look at it....we all like pic's?!
05-06-2011, 11:40 AM | #2 |
Re: airport find not sure of year.
Here's a few more pics.....
05-06-2011, 11:47 AM | #3 |
Senior Enthusiast
That is very cool. Thanks for posting the pics. Those are certainly the most unique 60-66 dash options I've ever seen. Too bad about the hole in the roof, but I can see why they wanted it. I can only imagine how many cool airplanes that thing has loaded and off loaded. I'm curious what those tubes are along the firewall above the valve cover.
05-06-2011, 12:14 PM | #4 |
Way cool!
What the heck kind of transmission is 2 gears? nice find, Rob.
'64 Corvair Ragtop '66 C10 Stepside "The oxen may be slow, but the Earth is patient" |
05-06-2011, 12:31 PM | #5 |
1961 crewcab
wonder if it really is only 6700 miles...?
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
05-06-2011, 12:37 PM | #6 |
Yeah, I should have asked if the speedo works, maybe that's where it died? and I think the owner mentioned he somehow had 3rd gear blocked, if that's possible?
05-06-2011, 12:39 PM | #7 |
I think those tubes (over the valve cover) are hydraulic for the footing jacks (you can see one of the jacks by the right side front bumper.
And yeah I beat a lot of famous folk have walked down these stairs since this belongs to the private terminal area. Last edited by robb67; 05-06-2011 at 12:41 PM. Reason: added info |
05-06-2011, 12:56 PM | #8 |
Who Me?
I would think those are actual miles. I also noticed the hour meter too. It probably did a lot of idling.
Cool find.
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
05-06-2011, 12:58 PM | #9 |
Who Me?
It may have a PTO to run the hydro's.
05-06-2011, 02:21 PM | #10 |
How about a slip and slide Powerglide? I'm sure this doesn't have a Powerglide but there are lots of two speed trannys.
I would bet the 6,700 miles are original, this thing just made short trips around the airport. You could restore this bit then what would you do with it? Drive around with a staircase? You could pull the airport equipment and restore the pickup but that would be a ton of work and you would need to get roof panels. I'm surprised this doesn't have a 305 V6. Posted via Mobile Device
The dude abides. |
05-06-2011, 02:26 PM | #11 |
1965 Chevy C10, 2005 4.8L/4l60
Use it for that loft apartment above the shop you always wanted!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
05-06-2011, 02:28 PM | #12 |
UCA63
Canadian models had I-6's
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) |
05-06-2011, 03:38 PM | #13 |
I'm betting that they blocked third gear so you can't drive it too fast. Looks a little top heavy to me and I think you could put it on her side pretty easily.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
05-06-2011, 05:02 PM | #14 |
the roof window is likely for alignment of the stairs to the plane...
the 'lines' are for sure hydraulics... the hours will mean more on a truck like this than the miles as it likely ran the entire time the plane was loading / unloading... there is another 'airport' truck on ebay right now that is a modifies 55-57 cassis... these are the 'hens teeth' that would be really cool restored to original application!!! |
05-06-2011, 06:18 PM | #15 |
I would so ride on top of that thing!
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
05-06-2011, 06:36 PM | #16 |
1961 crewcab
they have a neat airplane museum in seattle, and have jfk/lbj's airforce 1 that you can look at and go on, It would be awesome to see this truck restored and at at that display...
05-06-2011, 06:37 PM | #17 |
Bring it here to Texas, us red necks can have some fun with that thing
05-06-2011, 06:46 PM | #18 |
It might have 6700 miles, But all those miles were drivin in a 2 sqaure mile area. if it lived its whole live as a airport stair truck.
Anyway its a cool Time Capsule...
Measure with a yard stick Mark with Chalk Cut with a torch Built it yourself, don't count on others to to do it for you or with you. It will never get done |
05-06-2011, 06:52 PM | #19 |
I tried to find some history on the Miami company that built it but it is only mentioned in old documents from after WWII. Nothing about them going out of business or renaming themselves. If they were still around they may like to have seen it.
05-06-2011, 08:08 PM | #20 |
Check The Champ, Demonstrator
There was a similar truck at the airport in Aldergrove B.C. They wouldn't sell it. There was another truck at the same airport beside the helicopter hanger.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
05-06-2011, 10:18 PM | #21 |
Thats freakin cool!!!
05-06-2011, 11:06 PM | #22 |
Airport Bum
Yep, and some of us are on airports!
1964 Chevrolet C-10 1941 Chevrolet coupe 1962 Thunderbird 1959 Edsel Villager 1963 Skylark |
05-07-2011, 02:03 AM | #23 |
Heck the things only been used for 113.6 days if it was used 24hr a day, and the hydraulic pump is driven off the motor you can ust see the edge of it in one of the pictures,follow the hyd lines from the filter and resivoir to the right.
