Old 05-06-2011, 06:50 PM   #1
Jackie Mac
Need Engine/Trans 86 c-10
I am in the planning stages for putting a Rebuilt engine/trans in my 1986 Chevy Custom Dexuxe 10 Truck. It has a 305-v8 and a 3 SPEED auto trans. I am thinking a 350-v8 with a Good heavy duty Trans. This will be a work truck. I am new to this so any advice on a reputable place to purchace both would be greatly apprec. I live Close to Nashville Tn. Thanks Much and I am very Happy this forum exists !
Jackie Mac is offline   Reply With Quote
Old 05-06-2011, 07:06 PM   #2
tucsonjwt
Re: Need Engine/Trans 86 c-10
Can you define "work truck" in more detail? If you mean heavy hauling/towing work truck then a 454/400 is the ticket. If you mean daily driver with light to no towing or heavy hauling, then V6 with manual trans or 700R4 is the way to go. Rear axle can go as low as 2.73 for fuel economy to 4.56 for heavy towing.
tucsonjwt is offline   Reply With Quote
Old 05-06-2011, 08:38 PM   #3
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
I would check into a remnufactured GM Crate motor... as for the trans i have a local rebuilder who i use but there are several good trans places online like TCI
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 05-08-2011, 01:17 PM   #4
Jackie Mac
Smile Re: Need Engine/Trans 86 c-10
Thanks tucsonjwt and Old Rusty C10 for Reply. I will be using this truck for pulling a mowing trailer, a potential heavy load. I am thinking 454. I have never rebuilt an engine, but I want to do this myself. Would the Old 3 speed trans. hold up with the torque of a 454. What would be a good, preforably, auto. trans to put in the truck. Would truck need any frame/cutting mods to accept the 454 or just maybe an adapter kit? The simpler the betterfor me. Would anyof the parts offmy 305 adapt to the 454? (altenator, AC compressor ect.) Thank you guys so much for any info!
Old 05-08-2011, 02:58 PM   #5
PRattenbury
Have you ever built an engine before? If you haven't, you may want to save yourself some headache and just buy a GM Performance Parts crate engine. I mean, if you don't mind ruining some stuff and redoing some work, it would certainly be a good learning experience. But there's ways to do things, and special tools required even beyond the stuff a local machine shop would do for you, like torque wrenches, ring compressor, to name a couple. I don't mean to insult you or anyone. I have certainly ruined a lot of engine parts and redone a lot of my own work. I learned, of course. But it cost me. It's up to you. But if you want the simple, easy, most cost-effective way to do things... crate motor FTW.
PRattenbury is offline   Reply With Quote
Old 05-08-2011, 06:03 PM   #6
Jackie Mac
Good advice, I am going to speak to grooms engines in Nashville tn. They have short and long blocks as well as turn key packages with a great warranty. Thanks much!
Old 05-08-2011, 06:23 PM   #7
Matt Man
Matt Man's Avatar
a 454/400 with 3:73's would be a good combo.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 05-08-2011, 06:46 PM   #8
PRattenbury
^^^^ That would be a bullet proof combo. ^^^^^^
Old 05-08-2011, 09:27 PM   #9
Jackie Mac
454/400 Would I have to do much cutting/banging in the fender wells ect. to get that combo in? Thanks Much
Old 05-08-2011, 10:34 PM   #10
Jackie Mac
Oh yeah, What is the most durable/heavy duty trans for a 350 engine? Thanks
Old 05-09-2011, 12:48 AM   #11
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Get a 350 from a 96 and later truck. Slap on a carb and go. For power, you can swap out the cam. Easy swap. The cost of a transmission is high. A NV3500 can get you around. A NV4500 will pull just about anything have 5th gear for highway use.
In towing order of heavy use 400TH, 350TH and 700R4 (in 3rd only). The best combo is a 350TH/350 SB with 3.42/3.73 gears.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 05-09-2011, 06:50 PM   #12
Jackie Mac
Thanks Gchemist, Great info.
Old 05-09-2011, 07:20 PM   #13
sierra4x4
sierra4x4's Avatar
A 454 will simply bolt right on to your existing mounts. There is no cutting/banging required. You will need to get all of the accessory brackets for a 454 but your starter, alternator, distributor and carb will all bolt right on. An awsome all around combo is a 454/th400 with a 3.21 rear axle ratio. The 454 makes a ton of torque so you can get away with a taller axle ratio.
sierra4x4 is offline   Reply With Quote
Old 05-10-2011, 08:39 AM   #14
misternash2
call me crazy, but i'm gonna have to suggest 5.3/4l60e. it'll be a little extra work (not too much) and they have plenty of torque for pulling trailers. just throwing that out there. i bought engine, trans, computer, harness, first foot of pipe (for the flanges), stock airbox, etc. for $1500. put in new fuel tank, in tank pump, fuel lines, fittings, fuel pressure regulator/filter, radiator, flowtech knockoffs, etc for another $1800. sold the wore out engine and trans for $400. leaving me with right around $3000 in the swap, with fluids and filters. runs great, starts with ease, pulls a trailer with a car on it no problem. i love it in every way. i'm not getting the mileage i think i should be, but i'm pretty sure that a better tune would fix that. i'm getting 16mpg avg. still better than *most* carb'd 350s...
misternash2 is offline   Reply With Quote
