Old 05-06-2011, 08:59 PM   #1
Winola73
Cluster repair services?
I picked up a '91 instrument cluster with tach for my '88 last year but I'd like to have it tested and repaired before I install it and have the speedo recalibrated for my combination. Does anyone know of any good shops that do this on the older clusters? TIA.
Winola73 is offline   Reply With Quote
Old 05-07-2011, 11:48 AM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Cluster repair services?
There was a time, before digital stuff, when we could take a speedometer or a clock to a shop that could fix 'em.
Calibration may mean you need a different gear that drives the sender, or it could be a program issue, or a VSS. I have no clue. I buy stuff and think it's ready to go and install it blindly, and then find out it doesn't work.....
Doing your homework beforehand is good...
Member Nr. 2770
Old 05-07-2011, 02:00 PM   #3
scotts62
One day...
scotts62's Avatar
There is a module behind the glove box (slips my mind what it is called at the moment) that you can change to get the calibration closer. I had to change mine in my '92 when i changed gear sets and its closer but not exact.
Scott
93 crew cab build
Project 62
Old 05-08-2011, 06:09 PM   #4
Winola73
I could do the re-cal if I have to but I want the whole cluster tested, cleaned, repaired if needed and re-calibrated before I put it in. I found a place on eBay that will test, clean and calibrate it for $120, any repairs would be more. I'm going to give them a try.
