Old 05-07-2011, 10:56 AM   #1
Hazieview
Building Dreams out of Dimes!
Ordering My Be Cool Radiator... Can you guys look it over before I order it?
OK guys I finally decided on a radiator. I'm going with the Be Cool Aluminum radiater with dual 13" fans. It does not have an oil cooler or a transmission cooler. I am using external coolers for my trani and maybe one for my oil. (Eventually I will also be running Air Conditioning too.)
Well here it is:
http://www.summitracing.com/parts/BCI-80313/
Brand Be Cool
Manufacturer's Part Number 80313
Part Type Radiators
Product Line Be Cool Aluminum Power Cooling Modules
Summit Racing Part Number BCI-80313
Radiator Style Crossflow
Overall Width (in) 35.000 in.
Overall Height (in) 21.000 in.
Row Quantity Dual-row
Radiator Finish Natural
Radiator Material Aluminum
Transmission Cooler No
Inlet Location Upper driver side
Inlet Size 1 3/8 in.
Outlet Location Lower passenger side
Outlet Size 1 5/8 in.
Core Height (in) 18.500 in.
Core Thickness (in) 2.000 in.
Core Width (in) 27.500 in.
Tube Size 1 in.
Fan Included Yes
Fan Diameter (in) 13.000 in.
Fan Quantity Dual
Maximum Fan CFM 3,420 cfm
Blade Color Black
Blade Material Plastic
Shroud Color Black
Shroud Material Plastic
Quantity Sold as a kit.
Be Cool aluminum radiator power cooling modules are designed to properly cool your vehicle.
Kits include:
* Aluminum dual 1 in. core performance radiator with oval fluted tubes
* Aluminum fan mounting brackets or straps with hardware (where applicable)
* Diamond-cut, vented coolant recovery tank
* Fan wiring harness(es) with 40 amp relay(s)
* Be Cool billet radiator cap
* One 16 in., dual 11 in., or two 13 in. high-torque Euro black electric puller fan(s) (in selected kits)
* Natural or polished aluminum finish
* Bolt-in installation
* Fan upgrades sold separately
_______________________________________________________________
Here is my External Trani Cooler (may use this same cooler for my oil)
http://www.summitracing.com/parts/BMM-70265/
Brand B&M
Manufacturer's Part Number 70265
Part Type Fluid Coolers
Product Line B&M SuperCooler Oil Coolers
Summit Racing Part Number BMM-70265
UPC 019695702656
Overall Height (in) 4.500 in.
Overall Width (in) 11.250 in.
Overall Thickness (in) 1.500 in.
Cooler Construction Plate
Cooler Material Aluminum
Inlet Size 1/2 in. NPT
Inlet Attachment Female threads
Outlet Size 1/2 in. NPT
Outlet Attachment Female threads
Number of Cooling Rows 12
Core Height (in) 3.000 in.
Core Width (in) 11.250 in.
Core Thickness (in) 1.500 in.
Cooler Finish Polished
Quantity Sold individually.
Notes Does not include installation kit.
The last thing you need in the middle of a race or a road trip is to have a transmission or engine go south because your oil cooler can't keep up. B&M's SuperCooler oil coolers will keep your transmission or engine cool and running in your time of need. They're made of lightweight aluminum, with an efficient "stacked plate" design. Multiple cooling paths give them the cooling capacity of larger fan-and-tube coolers. And, because they have a low pressure-drop design, there is less oiling-system restriction.
Hazieview is offline   Reply With Quote
Old 05-07-2011, 12:49 PM   #2
jitteryguy
GoatLube Experss
jitteryguy's Avatar
Re: Ordering My Be Cool Radiator... Can you guys look it over before I order it?
way over price'd in my opinion, I would look at Jeg's or Summit brand'd product's.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 05-07-2011, 01:29 PM   #3
bnb0221
x2 summit has a nice setup
bnb0221 is offline   Reply With Quote
Old 05-07-2011, 02:38 PM   #4
ont_guy_38
ont_guy_38's Avatar
I have to agree on the overpricing . I think you could get something similiar with a shroud included for that amount of money . Something along this line
http://cgi.ebay.ca/19X31-GM-ALUMINUM...item45fa629ff1
ont_guy_38 is offline   Reply With Quote
Old 05-07-2011, 02:58 PM   #5
Pop's C-10
Pop's C-10's Avatar
What they said...
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 05-07-2011, 03:06 PM   #6
Hazieview
I agree the price is high. However, from what I researched, they Be Cool Radiators are excellent quality that wont let you down. I would hate to buy an off brand aluminum radiator only to have it leak on me in a few years...
I'm a 'Spend the money once' type of guy. I want something that will last.
Is anyone here actually running an aluminum radiator?
If so what brand?
Old 05-07-2011, 03:23 PM   #7
ont_guy_38
ont_guy_38's Avatar
Not saying they are not good rads but you are paying alot for the name
Old 05-07-2011, 05:45 PM   #8
muthstryker
muthstryker's Avatar
http://www.rondavisradiators.com/Radiators.htm
muthstryker is offline   Reply With Quote
Old 05-07-2011, 06:18 PM   #9
Hazieview
So is anyone running an aluminum radiator???
I have at least $6,000 invested in my engine that I'm trying to keep cool here.
I'll shell out the extra bones for a quality radiator. I dont want to go with a company no one has ever used or who isn't credible.
If anyone has any suggestions on a credible radiator that they have had experience with I'd be willing to take some advice.
Otherwise the post is going to be based off opinion instead of facts... Any pros out there?
With dual 13" fans on a 27.5" core I dont think I'll need a shroud....?
Old 05-07-2011, 08:13 PM   #10
mooseknuckles
mooseknuckles's Avatar
BeCool or Griffin.....it is a lot of money, but you get everything in the kit! .....an aluminum rad is def the way to go, especially if your having trouble keeping things cool...way more efficient!
mooseknuckles is offline   Reply With Quote
Old 05-07-2011, 08:32 PM   #11
CHROMAHOLIC
CHROMAHOLIC's Avatar
http://www.prchotrod.com/
CHROMAHOLIC is offline   Reply With Quote
Old 05-07-2011, 08:49 PM   #12
my4by2
my4by2's Avatar
Agree with the above comments - Be Cool makes a fine product no doubt, but they are WAY over priced for what it is.... Contact Ron Davis & see what he'll quote you to make one - his stuff is great too (pics of mine attached) & made specific for your application!!!
1977 Chevrolet K30 LWB Crew Cab
497HP Mast Motorsports 6.0L LY6 HO engine
GM NV4500 5-speed, Centerforce clutch + NP205
D60 + 14-bolt FF w/ Eaton posi + disc brakes
Skyjacker 2.5" full spring lift w/ Nitro shocks
Custom paint + interior
http://67-72chevytrucks.com/vboard/s...d.php?t=435722
my4by2 is offline   Reply With Quote
Old 05-07-2011, 09:13 PM   #13
ont_guy_38
ont_guy_38's Avatar
You probably won't need a shroud for cooling but I think it gives it a more professional look then just fans stuck on the rad
Old 05-07-2011, 10:11 PM   #14
Restrorob
The One And Only !!!
Restrorob's Avatar
Wish I could throw bux around like that....
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 05-07-2011, 10:51 PM   #15
78 Chevyrado
My $140 Stock replacement radiator hasn't let me down in 16 years.... And I run the max possible timing and drive it like I stole it, with the AC running. Run a stock rad on every square I ever had, and on my 87 I had a hopped-up 400 in it. Ran nice and cool with the stock 2 core 305 rad.
That's an insanely high price, (like a Rolex). I wouldn't go more than $450 or so max. If it makes you sleep better, get it right now, it's way more than you'll need, and from what i hear the quality is top notch.
78 Chevyrado is offline   Reply With Quote
Old 05-07-2011, 11:26 PM   #16
jitteryguy
GoatLube Experss
jitteryguy's Avatar
Summit and Jeg's dont manufacture part's, they sell major brand part's in there packaging. the quanity they buy in allow's em to sell for the price's they do.
I have a Jeg's radiator for my 383 in my MonteCarlo, I have'nt install'd it yet but made my choice base'd on how many other racer's were use'n em.
I understand be leary, but do some more research (as your do'n here) I think you'll find both company's sell a top quality radiator's.
'85 1/2 ton CCSB
'92 S10 350/350
Old 05-08-2011, 12:04 AM   #17
prostreetc10
prostreetc10's Avatar
here is a pic of my summit rad. it cost $168 about 4 years ago. and for the daul fans i went to the local junkyard and got the fans off of a chrysler sebring. they fit perfect. welded on the mounting tabs for the fans and that was it. little bit more work than ordering all together, but it is cheeper. and as far as keeping it cool, it never gets over 180, plus you can watch the thermastat open and close. the size is 31 wide 19 hieght and two row rad.
prostreetc10 is offline   Reply With Quote
